Old October 12th, 2011, 11:26
Brandon77's Avatar
Brandon77 Brandon77 is offline
Member# 3846
Coolant Sensor problem
So i need to get my temp. gauge working in my jeep on the dash before this weekend. I replaced the motor and opened the cooling system but now i have no temperature coming to the dash gauge. Im not worried about the acc. fan because i put it on a manual switch in the cab.
My question is the sensor below the exhaust manifold the temp. sending unit to the gauge or is it the one on the top, back driver side engine by the valve cover the one.
Can someone school me on this.
'89 2Dr XJ 4x4 Lerado AW4 NP231; 5.5" lift RE Springs & RC X-Flex S/Arms w/ drop brackets, w/ 33" KM2, 4.11 HPD30 Spartan Locker w/ Chromoly Shafts & D44 LSD w/ Chromoly Shafts w/ disk brakes.
...And remember to TREADLightly!
Old October 12th, 2011, 11:29
boostamante boostamante is offline
Re: Coolant Sensor problem
By the valve cover
Old October 12th, 2011, 18:40
8Mud's Avatar
8Mud 8Mud is offline
The sensor/sending unit on the top of the head, rear. The circuit grounds through the sending unit to the head. Make sure you have the head to firewall ground connected or you'll likely have more issues than just the temperature gauge.
An open circuit, bad or disconnected wire will peg the gauge one direction, grounding the wire straight to the head, should peg the gauge the other direction (with the key in the run position).
Using anything to to seal the threads on the sending unit may mess with the ground/continuity. You can test the sending unit ground by testing resistance between the sending unit housing and the head. Always a good idea to check resistance between the head and the firewall while your there and ohm test between the head and the negative battery terminal.
Old October 13th, 2011, 12:18
Brandon77's Avatar
Member# 3846
Awesome thanks you guys
Coolant temp sensor Jeff1 OEM Tech Discussion 8 February 27th, 2008 21:51
XJ Coolant Temp sensor jfiscus OEM Tech Discussion 6 January 28th, 2008 13:13
Coolant Temp Sensor Blaine B. OEM Tech Discussion 14 April 22nd, 2007 19:32
Coolant Temperature Sensor freewithfire OEM Tech Discussion 6 March 10th, 2005 05:28
Coolant temp sensor CutLaredo OEM Tech Discussion 5 November 21st, 2004 14:21
