nrpalmer32
- Eagle Creek, Oregon
I have an '87 XJ Wagoneer with the 4.0, NP242, AW4, 30" tires and 3.55 gears for starters. I have updated the cooling system to the newer open cooling system. During that update I installed a newer style heater control valve, radiator filler neck, all-aluminum radiator, 16lb radiator cap, overflow tank with window, and new hoses. I have also installed a FFDyanmics 3-fan cooling system, new water pump, 195* t-stat, and installed some vents in my hood. I installed a new fel-pro severe duty headgasket a few months back, but the problem has been prior to that. I had the cylinder head magnafluxed and machined, and it came out good.
The problem that I'm having is that when I drive in stop and go traffic, or slow offroad conditions, the system seems to build up enough pressure that it will fill up my overflow tank and spew all of my coolant out the breather hole at the top of my overflow tank. Then it ends up leaking all of my coolant out to where it overheats. The system will run steady at the line below the center line on the gauge until it leaks enough coolant out to overheat. So it seems its not overheating then building up pressure.
I can drive on the hwy all day long and it never has a problem. I can even drive over the Cascade Mtn range and have no problems. My first thought was that the fans aren't working, or cooling enough. Well they are definitely turning on and cool the engine down as soon as they turn on. It seems that the cooling system building up internal pressure is the problem.
Do you guys have any suggestions? I mean thats the main reason I installed the new head gasket but it didn't really change anything.
