Old August 30th, 2017, 01:12
rockclimber's Avatar
rockclimber rockclimber is offline
Associate
Re: XJ LM7 5.3 swap
I love the build,
but that Dana35 is not going to live long behind that kind of power.
[cal]You're an idiot rockclimber.
[StinkyFab]RockClimber is a tool.
Old August 30th, 2017, 09:11
burntkat burntkat is offline
NAXJA Member #1145
Re: XJ LM7 5.3 swap
Regarding the trans, install an inline filter and you just might be surprised. Clean fluid and proper filtration make a hell of a difference
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old August 30th, 2017, 12:00
indian's Avatar
indian indian is offline
Re: XJ LM7 5.3 swap
that could be true, but I installed new filter and new ATF but the trans makes a strange grinding sounds and clicks during shift also so I think after 130k mi it is ready to overhaul one way or another
Old August 30th, 2017, 23:47
NAXJA Member #1145
Re: XJ LM7 5.3 swap
I agree with you. But do realize the thing that goes in the pan is by no means a filter. It's more of a strainer. An inline, proper filter, will do a proper job. I suggest Magnefine filters, have them inline on my transmissions and power steering in everything I drive. Put them on the return line from the cooler so ant trash in the cooler is cleaned out, and you will greatly increase the mileage you get out of your equipment.
I'm running a built 700R4, predecessor to the 4L60e (they are quite similar in fact, I'm Using the 5-pinion planetarium out of a 4l60e) and I'm somewhere in the neighborhood of 200k without issue.
Inline filtration and the biggest cooler you can run should be the first things a geared adds to a vehicle he intends to keep.
Old August 31st, 2017, 00:50
indian's Avatar
Re: XJ LM7 5.3 swap
do you mean something like that?
http://magnefinefilters.com/NEW-Magn...6M-5610000.htm
Old August 31st, 2017, 09:42
NAXJA Member #1145
Re: XJ LM7 5.3 swap
Originally Posted by indian View Post
I mean precisely that.
They have recently changed their manufacture from Australia to the US, and from plastic screwed-together to steel, presumably welded.
Also, and FYI- I should note that I replaced the 42RE in my wife's ZJ 7 years ago. I had 6 years on the rebuild, and 95,000 miles without a fluid change (yes, I know. I'm lazy) This was because it's a royal PITA to change the fluid in trannies without a drain plug. The trans started shifting wierd- wouldn't shift till way late, if at all. I'd have to let off the gas and let it slam into gear. Lots of whining and wierd sounds.
I installed one of these and the problem went away. It's been fine since (over a year now) and has never shifted so well.
I can't say it will solve your problem- it likely won't. But for $20, it's not going to hurt, and should have come from the factory to begin with. There is good science behind the idea of this filter- the magnet catches the ferrous particles which are largely responsible for the cascading wear. The filter medium is much finer than that in the pan (as in, actual cellulose filtration media, not a nylon strainer) and I can tell you it does an excellent job.
I was having issues with the hydroboost brakes in my S10 self-applying. Looked at the fluid, it was dirty. I did some research and saw that dirty fluid can hang the spool valve up and apply the brakes. The ONLY change I made was to cut the return line and install one of these properly. Let it run for 5 minutes and the problem went away. The same fluid that had been brown with shiny flecks in it, now looked like it had just come out of the bottle.
Certainly, these are anecdotes. Your mileage may vary, not valid in Puerto Rico, etc..... but there's sound engineering behind it. A clean fluid power system is a happy fluid power system. *Especially* if it's a computer-controlled system (like the 4L60E). Those solenoids tend to attract the crud (steel) I referred to earlier, and get gummed up and start misbehaving.
Just don't get me started on lube oil bypass filtration.
Old August 31st, 2017, 22:39
clydefrog's Avatar
clydefrog clydefrog is offline
Re: XJ LM7 5.3 swap
I keep track of my tranny fluid color. I installed an inline filter (at Burnkats suggestion) right before a 6 US state, 2 country 3,300 mile trip, I can say that the trans fluid actually got cleaner (and these where all towing miles). Pretty sure it cost me less than $20. I'm running the 4L60E as well.
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old September 1st, 2017, 06:59
NAXJA Member #1145
Re: XJ LM7 5.3 swap
Glad it's working well for you, Clyde.
One thing to note- these filters have a flow direction marked on them. Follow that, it's crucial.
Why?They have a bypass valve in them. If you forget about it and don't change it, and the filter media gets plugged- the bypass opens. You no longer get the benefits of the cellulose filtration media (but do have the advantage of the magnet), and still have fluid flow so you don't burn the system up.
Put it in backwards, and the bypass valve is slammed shut by fluid pressure. Filter plugs, system starves of lube oil, and burns up.
I bet you money and beer anyone that's had a problem with these filters isn't what you'd call an attentive wrench, and didn't bother to verify proper install. However, it's been my experience that noone that actually runs them has anything bad to say. I've even installed a few in the parking lot of the local Oreilly's for people, to assist with their issues. (I'm the wierd, old guy that hangs out at the parts store, doesn't work there, and helps people out for free between research sessions for my latest project).
FYI- on the 700R4/4L60/4L60E series transmissions, the top line is the return line. That's where you want your filter installed, with the arrow pointing to the tranny. But let's leave Bruce Jenner out of this...
Old September 1st, 2017, 07:19
NAXJA Member #1145
Re: XJ LM7 5.3 swap
BTW, gents-
While the manufacturer's page does have the filters, be advised they charge like $7/filter to ship them. That's ridiculous.
Go to Ebay. http://www.ebay.com/itm/New-Magnefin...WnO l&vxp=mtr That's the same product, $25/filter, shipped to your door.
I just went to order two from the manufacturer's homepage- $54 all up. I can get them for $50 on Ebay. It's not a lot of difference, but 10% is 10%.
Old September 1st, 2017, 08:30
indian's Avatar
Re: XJ LM7 5.3 swap
I wanted to buy from this auction but the shipping to me is more than twice the price of the filter so I ordered the raybestos, hope it is similar quality.
Old September 1st, 2017, 10:08
NAXJA Member #1145
Re: XJ LM7 5.3 swap
Indian-
I can't comment for EU and the like. I would imagine there must be a Magnefine distributor in your country- as Magnefine started in Aussieland and distributed worldwide. I mentioned earlier they are now made in the US, I should say my country's distributor is manufacturing here. I don't know if they are still made in Oz as well- this gets into licensing, et al, that I have no clue about.
I've seen the Raybestos part in some 4X boards and car forums. It looked quite similar to the Magnefine product. There did seem to be some QC issues with them, namely with units arriving improperly assembled (not tightened down- the plastic units screw together). Simple check there is to make sure it is screwed shut snugly. Then keep an eye on it- but we should be looking for leaks and such with any motor vehicle to begin with, especially as enthusiasts that tend to tinker.
Didn't mean to take the thread off the rails, just trying to pay back some help I've received in the past. Can't wait till the OPs next installment
Old September 2nd, 2017, 00:38
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Re: XJ LM7 5.3 swap
Carquest sells the Magnafine filters, Orly may as well.
Sent from my SM-N910T using Tapatalk
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old September 17th, 2017, 09:27
indian's Avatar
Re: XJ LM7 5.3 swap
small update:
I fabricate some home made gas tank skid plate. I used relative thin sheet metal (2 mm - 14 gauge), but the bottom side has 2 layers. should be strong enough. it is relative solid..
The next step will be upgrade the brakes. I prepared the parts for WJ knuckle/steering/brakes swap. Had to clean the knuckles, drilled the rotors, buy bottom WJ ball joints, buy spacers and brand new mopar (akebono) upgraded WJ calipers - very nice piece, much bigger than stock XJ calipers. Hope the braking power will be notable better.
Otherwise I constantly mess with the HP tuners to tune the VE table and MAF calibration to accomplish small fuel trims (+- 2-3 %). It is not so easy like I thought, especially the MAF, but now it is almost done, the WOT AFR is perfect like commanded.
The oil pan is leaking even though I bought new gasket, but I don't know why. I put some sealant on the corners like manual says, tourqued the bolts in order like it should be, but the pan is leaking from behind. If somebody knows the trick, please tell me.
Old September 18th, 2017, 17:38
Jeepedo129 Jeepedo129 is offline
Re: XJ LM7 5.3 swap
Love my WJ brakes. No complaints here. I drove a loaded tandem axle u haul trailer across the country with it and had plenty of braking power. Best upgrade
Awesome build btw, has me thinking I should have swapped a V8 instead of my stroker.
Old September 18th, 2017, 21:23
Vintage Smoke Vintage Smoke is offline
Re: XJ LM7 5.3 swap
small update:
Exhaust - that was a never ending story. First I bought the magnaflow XL chamber muffler, but was too loud for DD, than I bought the Flowmaster 50 delta series - it was a little bit quiter but even thought too loud. The third muffler was the same I used with 4.0 engine but with bigger outlets - dynomax turbomuffler. It was the cheapest but the best sound for me, decent but noticable V8 sound.!
Google "The Story of Goldilocks and the Three Bears" LOL!!!
Sorry...couldn't resist!! In all seriousness that is fantastic work!!!
86 Radiator Core support swap/ AC swap ,,, need info AV8R TRANSPORT Modified Tech Discussion 6 August 16th, 2015 23:19
Brakes- booster/MC crapped out, debating swap to synthetic fluid during swap heshhash OEM Tech Discussion 7 December 6th, 2014 09:57
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 21:26
231 swap into a 89 xj with aw4 bcmaxx Modified Tech Discussion 6 October 17th, 2007 15:31
4 litre H.O swap vs. v8 swap... atowley Modified Tech Discussion 7 May 19th, 2004 13:40
