Old July 31st, 2017, 07:24
burntkat burntkat is offline
NAXJA Member #1145
Re: XJ LM7 5.3 swap
Are we certain that tiny little radiator will cool this engine?
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old July 31st, 2017, 07:29
indian's Avatar
indian indian is offline
Re: XJ LM7 5.3 swap
itīs not so tiny, itīs griffin 22" x 19" x 3" thick, that should work
racer32 uses the same and reports no overheating problems
we will see
Old July 31st, 2017, 08:00
NAXJA Member #1145
Re: XJ LM7 5.3 swap
Are you going to use an engine-driven fan, or electric?
Old July 31st, 2017, 08:23
indian's Avatar
Re: XJ LM7 5.3 swap
Electric fan with PWM modulator so I can ran it with lower RPM all the time like mechanical fan + GM PCM control + manual switch when needed fan always ON
Old July 31st, 2017, 10:58
cleenrob's Avatar
cleenrob cleenrob is offline
Re: XJ LM7 5.3 swap
I run the same size rad with no issue
It gets to about 206 sitting in traffic but that's it
Old July 31st, 2017, 11:16
NAXJA Member #1145
Re: XJ LM7 5.3 swap
Does it extend below the normal radiator's lower edge? got any pics of it installed from the front without the grill, for example?
I am curious if it does extend lower, how is it protected, and why don't more people use this sort of affair to cool a 4.0?
Old July 31st, 2017, 11:19
NAXJA Member #1145
Re: XJ LM7 5.3 swap
I may have said this before, so if I did, I apologize- and this is surely not to besmirch your work-
I think I'd add a lot more boxing to those motor mounts.
Old July 31st, 2017, 11:24
NAXJA Member #1145
Re: XJ LM7 5.3 swap
Also, the Jeep CTS adapter is awfully long, with no apparent way to vent.
I say this only because when I did the 350 swap into my S10, I ran a similar adaptation for a BMW dual-range temp sensor (so I could use two-speed fans), only to find out that I developed an air bubble below the sensor and so it didn't work- the air pocket insulated/isolated the CTS from the water, so it never tripped my fans. The solution in that case wound up being removing the adapter, tapping a bushing to fit the stock CTS location for the metric threads needed for the BMW CTS, and moving the stock CTS to the head. This removed all the air pockets in vicinity of the factory and BMW CTS, and it's worked a treat since.
That one took me a little while to suss out. I'm just trying to save you some possible headaches trying to reinvent the wheel.
Old August 1st, 2017, 01:06
indian's Avatar
Re: XJ LM7 5.3 swap
thatīs a good point. I also noticed the jeep CTS showed a little bit lower temperature than GM CTS but for me the Jeep CTS is only for gauge information purposes. Yesterday I checked the GM fan control and all ran good.
I adjusted the Fan ON temp to 95° C (203°F) and Fan OFF temp to 90°C (194°F) and the coolant temperature stayed within this range without problems. But this was tested only at idling.
What do you thing guys, what is the best operating temperature for this engine?
I looked at other calibrations like corvette, camaro, etc and every model has another fan control temperatures
Old August 1st, 2017, 01:07
indian's Avatar
Re: XJ LM7 5.3 swap
it extends not only stock radiator edge, but it extends the lower front crossmember, I will post a pic later
Old August 3rd, 2017, 23:34
clydefrog's Avatar
clydefrog clydefrog is offline
Re: XJ LM7 5.3 swap
I run my LS swap at ~197 -to- 201. Runs pretty good at that temp. My second fan is programed the same as yours (on at 204 and off at 194). My third fan only comes on with a/c and the first fan comes on at 165...so its always on. I also run a manual switch...just in case. The stock truck runs around 210 I think and the Corvette at 220. Mine only gets up to 210 when pulling a trailer uphill at 70mph.
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old August 4th, 2017, 00:43
indian's Avatar
Re: XJ LM7 5.3 swap
thanks clydefrog. I have only one bigger fan, so I will run it always on with the PWM regulator at low rpm and if the temperature rises above 203°F the PCM with turn on to the max rpm
Old August 29th, 2017, 01:20
indian's Avatar
Re: XJ LM7 5.3 swap
small update:
I have few hudreds of miles on it and have to say this LS swap was the best mod I've ever done to my XJ. The ride is much much better with the V8. It's not about the peak power but the torque delivery in low rpm from this truck engine (LM7) is beautiful.
All gauges except tach are working. I installed small external tach but in the future I would like to have some modul to work with the stock tach. (novak or a home made modul).
I began to mess with HP tuners and the results are noticable:
First I modified the VE table. I went from this:
to this:
and now the fuel trims are about 0 all the time. I also changed the torque management, MAF table, some shift points, etc.. There is a lot to do with this software.
Yesterday I made some underbody protection. I feel the previous color of my rear dif boring so I decided to go the "rat style" way. I grinded the color away and applied few layers of clear paint.
I also sprayed the fender flares with the underbody coating to get similar texture like the raptor bedliner on my body:
Now the XJ looks like this:
Other things:
Transmission - the 4l60e is whining during the ride so I thing the next big repair will be the overhauling of the trans
Fuel pump - the stock 2001 jeep fuel pump has enough pressure even at WOT (65 psi).
Exhaust - that was a never ending story. First I bought the magnaflow XL chamber muffler, but was too loud for DD, than I bought the Flowmaster 50 delta series - it was a little bit quiter but even thought too loud. The third muffler was the same I used with 4.0 engine but with bigger outlets - dynomax turbomuffler. It was the cheapest but the best sound for me, decent but noticable V8 sound.
If somebody is thinking about LS swap, just do it!
Old August 29th, 2017, 23:38
clydefrog's Avatar
Re: XJ LM7 5.3 swap
Nice!
Isn't the torque awesome! Looks clean!
Dont know if your intake is still not heat protected (going off the pic above) but on mine I hooked it up to a snorkel for true cold air. If you watch the fuel trims and the intake temp you will start to see it lean out at 150-160 degrees (intake temp F). The biggest power gain I saw on my LM7 was when I made the intake a true cold air intake, HUGE difference in power.
Old August 30th, 2017, 01:00
indian's Avatar
Re: XJ LM7 5.3 swap
Nice!
my filter is just behind the grill besides the rad, so my IAT is the same like the temp outside
86 Radiator Core support swap/ AC swap ,,, need info AV8R TRANSPORT Modified Tech Discussion 6 August 16th, 2015 23:19
Brakes- booster/MC crapped out, debating swap to synthetic fluid during swap heshhash OEM Tech Discussion 7 December 6th, 2014 09:57
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 21:26
231 swap into a 89 xj with aw4 bcmaxx Modified Tech Discussion 6 October 17th, 2007 15:31
4 litre H.O swap vs. v8 swap... atowley Modified Tech Discussion 7 May 19th, 2004 13:40
