Old November 30th, 2016, 06:11
LKN_xj LKN_xj is offline
1991 XJ Limited - Project "It's About Time"
Just filled up the tank and apparently I'm getting 14.5 MPG, pretty much in town and under 10 minute drives...I must have a baby foot. Could be due to the fact that the cracked manifold won't let me accelerate above 3000 RPMs but I would have thought the O2 sensor would be making it run falsely rich offsetting that.
Old December 3rd, 2016, 14:20
I pulled into the driveway today and realized that coolant was dripping from the front of the passenger side engine bay. Turns out it's an upper radiator hose. I already knew I'm dripping a drop of PS fluid as well, and also know the lower radiator hose is pretty swollen. On top of my exhaust manifold that needs replacing.
The Jeep is parked for a while, consequently. I'm tearing down to do the manifold replacement first, then work my way back out with Brown Dog motor mounts, lower rad hose, PS pump and then upper rad hose. Hopefully I'll solve the leak problems except for my rear main.
Old December 4th, 2016, 08:09
trippled trippled is offline
Re: 1991 XJ Limited - Project "It's About Time"
Unless that crack is absolutely massive, don't hold your breath for it fixing your running problem.
Old December 4th, 2016, 12:53
Not sure I understand the comment as I wouldn't qualify my jeep for having a problem running. I can stick my hand by the crack and it blows the hairs on my arm and my engine mounts are original to the jeep. It cranks up, drives and performs. It's doesn't perform as well as as it did before I developed the crack. So I'll hold my breath for a bit of improvement, undoubtedly.
Old December 4th, 2016, 22:05
Not accelerating past 3k was my point. Sounds more fuel pressure related than an exhaust leak. But those exhaust leaks are annoying as hell.
Old December 5th, 2016, 10:23
Interesting you say fuel pressure. When I removed the fuel rail, after pulling a muscle in my neck because the injectors were so stuck in there, I relieved the pressure in the rail only to find the Schrader valve didn't spit any fuel. I honestly can't remember if I pulled the fuel line first, or tried the valve. Either way I recall that being strange.
By the way, has anyone ever hot tanked their intake? Mines pretty nasty and I found a guy who has a bath for aluminum and he'll blast it clean then soak again for $50. Figured I'd give it a try.
Old December 9th, 2016, 13:33
Much better
Old December 9th, 2016, 15:38
ftwelder's Avatar
ftwelder ftwelder is offline
WOW that looks nice. You may be able to reduce stains by wetting it with armorall.
endless jeep project that will eventually end up as a rust bucket in someones backyard.
Old December 9th, 2016, 15:52
Thanks -I like that idea. I believe I'm just going to paint it black. My objective was t necessarily for it to look pretty, but more to remove the CRAZY carbon and gunk deposits in both the intake ports and also the injector ports. It was so dirty and junky that I am willing to bet that not a single injector would seal upon reinstallation.
Also, I'm very paranoid about glass beads in the engine. They washed it at the shop, but I took it home and blew out all threads and ports, then washed in my bathtub then repeated a few times till I felt OK about it.
Old December 10th, 2016, 21:32
Made in 'Merica!
If you need motor mounts, buy brown dog. Top of the line, and customer service is not notch.
My motor mount rubber was basically gone on the drivers side. Passenger actually wasn't that bad.
Old December 11th, 2016, 19:20
Getting there - motor mounts done, exhaust manifold mounted and intake manifold painted and mounted. Getting that thing torqued down was not a walk in the park.
Old December 13th, 2016, 15:26
PacificEd's Avatar
PacificEd PacificEd is online now
Regular Joe
I just read your build and you have done a great job assembling the parts that work for you. That is what is the most fun. Keep it up.
Former SEC Chapter President: 2009-2012
Former National Recorder: 2013-2016
Old December 13th, 2016, 18:12
Thanks! It ain't perfect, but I'm trying to get her back up from a reliability standpoint, then focus on aesthetics again.
It will be around for years to come, so I'm not counting cash right now...
Old December 14th, 2016, 07:32
90xj06's Avatar
90xj06 90xj06 is offline
what head casting is it? im not 100% sure but the 7120 and the 0630 have the same port setup. but the 0630 does not have the threads for the temperature sensor for the dash. you can drill and tap or make something creative.
Old December 14th, 2016, 18:30
I got everything buttoned back up to test for fuel leaks. I'm not leaking at the injectors, but I am leaking a few drops from leach fuel line connector going into the fuel rail.
What is the likely cause of this?
"Part Time" Dash light.... I need mine to say "Party Time" mako my day OEM Tech Discussion 23 March 2nd, 2013 07:36
Gear oil for "Limited Slip" Do I still add "additive"? my2monkeys OEM Tech Discussion 1 February 5th, 2012 09:43
1991 Jeep Cherokee Limited 4.5" IL Fast95Neon MWC For Sale/Wanted Forum 4 October 19th, 2008 20:45
3" lift and limited time Poppinblock Modified Tech Discussion 2 April 18th, 2006 00:16
