Old August 16th, 2016, 15:55
LKN_xj LKN_xj is offline
1991 XJ Limited - Project "It's About Time"
Originally Posted by Dragonlich1961 View Post
About 1/8 inch toe in. So 67 7/16 front and 67 9/16 rear. 1/8 difference. In and out for toe refer to the relation of the front of the tie to center.
Thanks! I've been using the edge of the tire thread because it's a sharp corner. It's a relative number as long as it's the same spot front and back. Thanks for the number I'm shooting for.
Old August 17th, 2016, 14:40
I'm fixing to replace the UCA bushings on the axle. Why is one bushing (passenger side) fully pressed into the axle but the other (drivers) is only partially pressed in? Is this for alignment of the arm?
You can see in this picture how it's not fully pressed in. It's like that on all axles that I've seen.
Old August 18th, 2016, 18:05
Read somewhere that the drivers side boss is a smaller ID so the bushing only presses in but so far. All good.
A little progress today: I was able to get the alignment done. I'm about an eighth toe in which is indistinguishable to the eye. The camber problem seems to have gone away. Must've been an optical illusion. I also adjusted the steering wheel alignment so it's nice to not be driving with the steering wheel upside down.
Learned something new: don't try to adjust the drag link if your steering wheel is locked. You're definitely not going to get anywhere.
Old August 19th, 2016, 10:04
dantheman! dantheman! is offline
Re: 1991 XJ Limited - Project "It's About Time"
haha yea i made that mistake too about adjusting the drag link. sat there going what the hell isnt the pitman arm moving? for probably 2-3 minutes before my brain clicked.
Old August 19th, 2016, 10:09
My brain didn't click until I maxed out the adjuster and I was pushing my passenger side wheel toe out...
Old August 19th, 2016, 11:15
The guys at the tire shop are wondering if the 285/75's will fit
If not I brought tools to take the flares off.
Old August 19th, 2016, 12:04
dan1977p's Avatar
dan1977p dan1977p is offline
33's will fit but you just can't fully stuff them. Driving around town will give you no issue at all.
91 Sport 4.0L, aw4, np231, 4.5" long arm, 33" BFG AT KO's - SOLD
SeXJ Build Thread
Old August 19th, 2016, 12:07
Yep they fit
The plan for the future is bushwacker flat flares and 305/70's bit this will get me through the winter
Old August 19th, 2016, 12:08
The RE leafs and springs are STIFF. Barely any change with the weight of the jeep on them from a tire clearance perspective.
Old August 19th, 2016, 14:51
TRCM's Avatar
TRCM TRCM is offline
are those 16 or 17 rims ??
Old August 19th, 2016, 14:53
They're the 16" Moabs from the Rubicon wranglers. 03-06 I believe.
Old August 21st, 2016, 19:04
Parts!!
From left to right. New bearing hubs, Spicer ball joints, Spicer spindles, u-joints, upper control arm bushings, axle tube seals, and in the back a lube locker for the D30 and an Olivers double cardon shaft.
Old September 5th, 2016, 16:02
Header panel swap. Honestly not quite as clean of a swap as a lot of people say. There are some strange snags but everything is workable. I have some touching up to do but it's done. Also, pardon the missing fog light. The car wash stole it.
Old September 27th, 2016, 18:39
Out with the old...
Old November 17th, 2016, 10:31
Ripped out the old Bendix 9 system and replaced with a simple booster from a 95. Required the pedal to be swapped as well. Night and day difference.
"Part Time" Dash light.... I need mine to say "Party Time" mako my day OEM Tech Discussion 23 March 2nd, 2013 07:36
Gear oil for "Limited Slip" Do I still add "additive"? my2monkeys OEM Tech Discussion 1 February 5th, 2012 09:43
1991 Jeep Cherokee Limited 4.5" IL Fast95Neon MWC For Sale/Wanted Forum 4 October 19th, 2008 20:45
3" lift and limited time Poppinblock Modified Tech Discussion 2 April 18th, 2006 00:16
