Old April 5th, 2014, 20:18
blistovmhz blistovmhz is offline
Re: WJ knuckle swap and 1-ton steering complete
Originally Posted by markw View Post
That trackbar to the tube weld doesn't look like it got any penetration on the tube side. Might want to look at that. Last thing you want is your track bar mount ripping off the axle going down the road.
Eyup. That's me not knowing that you can't weld 7018 upside down .
It's welded all the way around all edges inside and out, and the other welds are much better (not fantastic, but much better). I'll be ripping it back off when I've got the front end off while I do the transmission (hopefully soon), and do it up properly with my new mig.
It's been wheeled pretty hard though as it is, seen a few decent jumps, and tonnes of side-loading, and doesn't seem to be moving. I figure if it doesn't break on the trail, it's not going to fall off on the highway.
Old November 18th, 2015, 11:43
So I just had another set of uni's fail on my setup. I decided to try some SKF Uni's this time as I've heard they're a bit stronger.
For my swap, I'd ORDERED 2001 Uni's (Timken), but when I compared the Timken to the SKF, the SKF is 1/2" shorter. With the Timken uni, I needed to add a 1/8" washer between the knuckle and caliper to get the spacing correct for the 04 sporttrac rotor hat height. I've heard this is common, but that some guys need it and some don't.
The SKF being 1/2" shorter, meant that that 1/8" spacer was no longer necessary. In fact, with the shorter Uni, the rotor is actually almost too close to the TRE. I've got it installed but there's really only about 1/4 to 1/8" clearance, which I'm hoping won't result in the rotor melting the TRE boot.
Also, with the hat further in, the rotor JUST grazes the inside pad clips. It's so slight that I'm just going to run it and see how it goes. It looks like it's got less than 1 thousandth touching, so the clip should wear down. I COULD hammer the inside of the clip a little flatter, but wanted to see what happens.
But, just wanted to mention this. I've had 3 sets of Timken Uni's, all of which were supposed to be for an 01 XJ, but all of them seem to be no different than the uni's for a 98. I suspect that a lot of vendors (including rockauto) have the timkens listed for the wrong application, and the SKF is correct. Or it could be that the SKF is just shorter than it's supposed to be. Either way, the SKF unit is thicker in every direction, shorter (less leverage), and the hub comes all the way out to the wheel flange (the Timkens have a 1/2" gap). I believe the SKF actually locates the outer bearing immediately behind the wheel flange, which sure would help for strength.
Anyone else run into this though? Were all my Timkens just the wrong part?
Old November 18th, 2015, 16:27
Anak's Avatar
Anak Anak is offline
Mostly Harmless
Any chance you could post some pictures with measurements of the relevant dimensions?
I have a pair of Timkens waiting on this project, but nothing available with which to compare them.
Old November 18th, 2015, 17:47
Randy_66 Randy_66 is offline
I'm following this too, a friend's WJ motor just cratered and I get to help myself to whatever I want before he takes the carcass to the yard.
New one is the SKF BR930219.
Older is the Timken 513084
0.25" difference in stick out. With the Timken, I needed a 0.125" washer between the caliper and knuckle. With the SKF, the caliper mount is a touch too far out and could probably do with a bit of a shave, but I'm running it. Seems fine.
What gets me though is that the Timken unit SHOULD be the same stick out. I strongly suspect everyone just has the wrong application listed for the Timken unit.
Old August 7th, 2017, 14:19
TrailTamer XJ TrailTamer XJ is offline
I just did this WJ knuckle swap.
I want to clarify that the post above with unit bearing pictures is wrong.
The newer unit bearings is 1/4" shorter than older unit bearings.
In the picture above on left (new) is for 1999-2006 Jeeps, on right (old, Rusty) is for 1989-1999 Jeeps.
I did my WJ knuckle swap on my 1998 XJ and used the newer generation unit bearings as the one on left in the picture to avoid caliper spacers.
Old August 8th, 2017, 15:05
The Timken part I had (rusty) was what pretty near everywhere listed for 01, which is why I got it in the first place. You may be correct though. Either way, the SKF part is the one I ended up using, which as you say, does away with the caliper spacer requirement, and the decreased stickout is WAY stronger than the other units. I had 50k on the SKF's with no sign of wear, whereas I was blowing out the longer units every 3-4 months.
Old December 15th, 2017, 16:24
bkdezalia bkdezalia is offline
I hate to revive a really old thread, but having a compounding issue here...
Problem #1. I used everything the OP (Dusty's) parts list, the first issue is that the 01 unit bearings won't fit inside of an 01 SportTrac rotor, tested out a Comanche hub, which fits inside the rotor...
Problem #2. On the driver side (short axle shaft) when I bolt either an XJ, TJ, or Comanche hub to the WJ knuckle with the spacer welded on, the shaft binds when moving it back and forth, like it's being pushed in to the carrier...
Thoughts?
Old December 15th, 2017, 16:40
RCP Phx RCP Phx is offline
Thoughts?
Need lots more info...........What year, what year axle?
Old December 15th, 2017, 16:42
Thoughts?
1. Do you mean the rotor doesn't fit around the od of the hub? That's normal. Just put it on jack stands, 4wd, and grind the hub flange until the rotor fits. You only have to take off less than 1/16.
2. Not following .... Video and pictures?
Old January 3rd, 2018, 12:03
"Used OP's parts"
'96 XJ axle
WJ knuckle swap JKS steering question truck7575 Modified Tech Discussion 12 June 12th, 2011 22:34
WJ brake/knuckle/steering swap to a ZJ peej08 Modified Tech Discussion 11 April 26th, 2011 21:00
quick WJ knuckle/brakes/steering swap question about TRE's huntingman2706217 Modified Tech Discussion 9 March 11th, 2010 07:47
Steering stabalizer on WJ knuckle swap...? 89xjgrey Modified Tech Discussion 15 May 15th, 2009 15:06
Complete HP D30,ARB,With over the knuckle hiem steering David Taylor For Sale: Private Party Only. XJ ITEMS ONLY 3 November 10th, 2003 21:52
