Old October 30th, 2017, 12:39
burntkat burntkat is offline
NAXJA Member #1145
Re: Coolant Filter install - 2000 XJ
That's a manual for the AW4. I'll give you that.
A search for "pressure" and "PSI" doesn't indicate anything relevant to the discussion.
Please advise? I'd be quite surprised to find higher than 50PSI in the cooling circuit, where the cooling circuit is defined as the lines going to/from the radiator transmission cooler.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old October 30th, 2017, 13:07
RCP Phx RCP Phx is offline
You brought it up !!!
Originally Posted by burntkat View Post
Transmission cooling lines might get to 50PSI, max.
See pg7-8, 53-272psi !
Old October 30th, 2017, 13:27
Yes, but do they have an internal bypass valve so they don't stop flow if clogged?
No, but visual is there all the time, plus you could hook-up a idiot light/ pressure gauge to monitor on the road!
Old October 30th, 2017, 15:03
Mach2nh Mach2nh is offline
Hose clamps on the trans line are 100% fine. How do you think most people including myself install auxiliary coolers? Very few are hard lined that i have seen.
Old October 31st, 2017, 06:52
NAXJA Member #1145
I do precisely the same as Mach2nh. I've been doing it for, oh, 27 years now. Never a problem.
Old October 31st, 2017, 06:54
NAXJA Member #1145
And again, those are INTERNAL pressures, inside the valve body.
The cooler circuit is LP. Literally less than 50PSI. MUCH less. Don't believe me,. disconnect a hose and see how much it squirts. (Answer- not much at all).
2000 XJ 1 Gal+ Low Coolant?? 1987Comanche OEM Tech Discussion 10 March 8th, 2010 07:19
does a 2000 xj have an engine coolant.... milehigh OEM Tech Discussion 2 March 8th, 2009 15:50
Tefba Coolant Filter Group Buy - Part 2 djblade311 SoCal For Sale 33 June 5th, 2008 20:58
Coolant Filter.... XpedientJ Modified Tech Discussion 2 August 10th, 2007 21:16
Coolant on my air filter Poppinblock OEM Tech Discussion 1 April 11th, 2006 22:41
