Old August 29th, 2009, 07:10
FallibleXJ FallibleXJ is offline
Jeep won't start
hey folks. I've been on a road trip from CA to NY. Last night as I pulled into a hotel after driving for 11-12 hours I pulled into the awning area so I could go find a room. my electric fan didn't turn off (this has been a recurring problem) so I popped the hood and reset its relay, I have done this a few times before. When I came back out to move my jeep about 10minutes later it wouldn't fire. Turns over just fine, there is fuel pressure in the fuel rail, and the battery is putting out over 12 volts.
I had to get my jeep out from under their awning so a local truck came by and we pushed it out of the way. He tried listening for the fuel pump through the gas tank? He also tried hitting the gas tank to try "vibrating the fuel pump so it will start" I hadn't heard of either of these techniques, but hey what do I know.
I thought maybe I had pumped on of the other relays while I was in there, and it is certainly possible. I pulled out the Fuel Pump and ASD relays and reset them just as a check and still no go. I had it shut down at a rest stop about 45minutes prior to the failure and it started just fine then.
The past month or two I have been having a few odd problems, just throwing them out here too just incase it is related:
  • Speedometer and RPM gauge die periodically and come back again after a few minutes
  • Cruise control dies periodically, same time as above
  • Electric Fan stays on after jeep has been shut off
  • Takes several seconds to start up some mornings
Its a 97' Cherokee
Old August 29th, 2009, 08:22
joe_peters joe_peters is offline
Re: Jeep won't start
You say "reset" the relays, which makes me think you have pulled them and put them back in the same spot.
Have you tried swapping the relays?
The fan staying on sure sounds to me like a sticking relay. Check the numbers and try swapping them around--not sure on the 97 if the ASD is the same as the others. If the problem is the relays stop at a salvage yard and grab yourself a handful so you have some spares on board.
Old August 29th, 2009, 08:35
winterbeater's Avatar
winterbeater winterbeater is offline
You could try unplugging and replugging the crank position sensor a few times to refresh the connection. Maybe corrosion over time decreased continuity. (admittedly a long shot)
Old August 29th, 2009, 09:00
x2, not all that much of a long shot. Your fan staying on may not have any relation to the no start.
Old August 29th, 2009, 09:11
It was very humid and rainy throughout the day, which could add to the corrosion. I'll check that
EDIT: This could have been a rookie mistake. Since I have been driving cross country I've had to refuel many times. Normally I put in 97 Octane, however there was once that I put in 86 octane due to availability, and a couple times I put in 89 because it was cheap (comparatively).
Old August 29th, 2009, 09:58
ASD relay!
Good call guys. Peace out, thanks much
Old August 29th, 2009, 14:21
Great! Hope your trip goes on w/o any more problems.
Jeep no start HeavyMetal OEM Tech Discussion 5 April 17th, 2009 04:35
Please help! jeep won't start rc_mx5 OEM Tech Discussion 9 January 1st, 2009 08:48
Jeep won't start ZacSquatch OEM Tech Discussion 5 February 20th, 2007 19:32
Jeep will not start Undeclared OEM Tech Discussion 1 March 2nd, 2005 17:53
Jeep No start buffalomatt350 OEM Tech Discussion 4 August 4th, 2004 20:43
