Old August 25th, 2009, 12:35
Danwa Danwa is offline
np242 transfer case
Does anyone know what the small brass plug at the bottom of the np242 transfer case is? It appears to be leaking. This is on an 88 cherokee. Thanks
Old August 26th, 2009, 11:06
Hudson Bend Hudson Bend is offline
Re: np242 transfer case
A drain plug? Do I win?
Old August 26th, 2009, 11:10
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
mine leaks there too. could be a drain plug, maybe an access/inspection hole as well. but i dont know for sure.
Old August 26th, 2009, 12:31
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
I'd have to guess a drain plug, though I don't believe I've ever seen a brass drain plug.
Is it the same shape and size as the fill plug further up the case? My parts catalog shows two #4210616 being required for the NP242 transfer case, one at the bottom of the rear casting and the other further up the rear casting. If in doubt, don't remove it. This won't happen on a 242, but I know of some manual transmission models on other vehicles that appear to have two fill plugs - there are two bolts that look exactly the same from the outside. However, if you remove the wrong one, it actually is the fitting that holds the end of a shaft in place - removing it allows the shaft and portions of the shifter linkages to fall down inside the case! This resulted in a garage I worked at paying to rent a car for one of our customers and repairing his transmission free of charge after one of the less-than-intelligent techs pulled the wrong bolt while doing a fluid change.
Old August 26th, 2009, 15:33
KaiserMan's Avatar
KaiserMan KaiserMan is offline
Probably an inspection plug to check the slack in the chain. Jeep BW QT's had one for that purpose.
Old August 26th, 2009, 20:18
mfascuba mfascuba is offline
Got a picture? The only two plugs to mess with on an NP242 are on the back of the unit, one for draining the other for filling. I think the one you're talking about is a pivot point for internals - don't take it out unless you're taking the whole transfer case apart to rebuild it.
My two cents...
Mark
Old August 26th, 2009, 20:34
fyrfytr1717 fyrfytr1717 is offline
NP242 fill and drain plugs (outside view)
NP242 (inside view)
That's all there is, at least on my '99 anyways. Incidentally, when draining your TC, remove the fill plug first, then the drain plug. This will allow air into the case while the fluid is draining and prevent it from "glugging" fluid all over the place.
Old August 26th, 2009, 20:41
1990JEEPXJ's Avatar
i will snap a pic of it later and show you what he means.
Old August 27th, 2009, 06:18
Yes Kastein and others,
I was worried about internals issues. I think I read somewhere that there was a detented shaft and spring connected to that plug. Anyhow, again, it appears to be brass right at the bottom of the case. I do know where the drain and fill plugs are, I just wanted to get this leak fixed without having to take apart the case. Oh well, maybe it's time. I have 251,000 miles on it now.
Old August 27th, 2009, 08:38
It also prevents you from being up a creek without a paddle should your fill plug be frozen... unlikely to happen with brass in an aluminum block, but still not something I like to take my chances with. Incidentally this is also why you should *always* remove the engine oil fill cap before draining the oil.
Old August 27th, 2009, 21:47
I'm curious now... is it on the front half of the case? 54 in this picture?
Old August 27th, 2009, 22:09
I think he's talking about #20 in that picture, but not sure...
Old August 27th, 2009, 22:44
1990JEEPXJ's Avatar
not #20. its not the conventional fill and drain plugs.
Old August 27th, 2009, 23:59
# 54 is the brass plug - has to do with the shifting mechanism.
Mark
Old August 29th, 2009, 09:47
alfman's Avatar
alfman alfman is offline
#54 should be the sift detent ball, spring & plug. If it is leaking you can back it out a turn or two, clean it up with brake cleaner, squirt a little silicone sealer in between the head & the case & tighten it up. Should stop the leak.
Don't piss on my back & tell me that it's raining
2000 XJ Sport 4 door - stock, 4.0, AW4, NP231
1990 XJ Limited 4 door - stock, 4.0, AW4, NP242
1987 XJ Pioneer 4door - 4.0, AW4, NP231, plow, (lift, etc in the works)
NP242 transfer case Dundy NAC Classifieds 2 March 25th, 2008 17:59
Looking for a np242 transfer case cherokeefun Sierra Chapter 11 April 28th, 2005 14:28
NP242 Transfer Case RCP Phx For Sale: Private Party Only. XJ ITEMS ONLY 0 December 3rd, 2004 17:05
NP242 Transfer Case SYE SnowyXJ Modified Tech Discussion 13 December 2nd, 2003 10:07
NP242 transfer case questions tacottle OEM Tech Discussion 1 October 6th, 2003 13:20
