SuperRA
- Santa Clara, CA
For anyone that has a real renix wiring diagram (not reprinted from pirate etc, those too blurry) I've found some errors that drove me crazy for a little bit. In my manual #8980010547, USA Canada ed. revised Jan 1987, the pin out at the ECU for "Latch Relay" says it's B9 when in fact it is A9 and this is confirmed in the ECU connector chart. Also the diagnostic connector pin is printed as "D2-6" when in fact it is D2-3 confirmed in the diagnostic connector chart on the next page. I've traced the wires on my own jeep and have found these corrections to be true. Other errors that I have seen on the diagram but not verified are pin outs for shift light, EGR, F/P relay, inj #4 & inj#6.
This brings me to the question of relay positions. In the manual, it says that they are ,from front of the vehicle to the back:
1. O2 Sensor
2. Fuel Pump
3. B+ Latch
4. AC clutch
were on my jeep they are totally reversed... I did take them off the bracket a little while ago to clean that area. I thought I put them back correctly, but just wanted to verify one way or the other from anybody else.
1. O2 Sensor
2. Fuel Pump
3. B+ Latch
4. AC clutch
