Old October 7th, 2017, 10:53
Francesco Francesco is offline
Re: Renix Issue
The hose is new, but I will try replacing the map with a spare I have(not tested unfortunately), and maybe doing Cruiser's map upgrade by tapping the TB today.
Old October 7th, 2017, 13:16
cruiser54's Avatar
cruiser54 cruiser54 is offline
Re: Renix Issue
Originally Posted by Francesco View Post
Regardless, I have cleaned the ground at the block, the ground at the valve cover, added an extra ground from firewall to fuel rail, and from battery to core support area. I really don't think it's a grounding issue. I also have pulled the main harness plug, cleaned that, and filled with ox-gard equivalent.
I'm not sure that's a good idea. Ox-gard is conductive.
Old October 7th, 2017, 13:54
Re: Renix Issue
I see. Should I pull and clean it? I did this quite a long timeago(6-7 months) and haven't had issues until like 2 weeks ago after my Jeep sat for 2 weeks.
Old October 7th, 2017, 14:09
cruiser54's Avatar
Re: Renix Issue
Hard to say. Maybe not now, but keep that on your radar screen.
Old October 8th, 2017, 10:17
Re: Renix Issue
Well I have parts coming on on Tuesday to do your MAP sensor line upgrade, since my line has been heat shrunk and repaired anyways, I figure it's worth it.
Old October 9th, 2017, 07:58
burntkat burntkat is offline
NAXJA Member #1145
Re: Renix Issue
What is this MAP upgrade??
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old October 9th, 2017, 07:59
Re: Renix Issue
Basically you remove the rubber plug from the throttle body, tap it, and use a brass fitting for a better seal.
Old October 9th, 2017, 08:21
cruiser54's Avatar
Re: Renix Issue
http://cruiser54.com/?p=280
Old October 9th, 2017, 11:11
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Re: Renix Issue
Originally Posted by cruiser54 View Post
In my opinion that should be closer to the top ten
Old October 9th, 2017, 17:27
Re: Renix Issue
Well, you can only have so many in the top ten.....ten to be exact
Old October 9th, 2017, 18:48
NAXJA Member 4950
Re: Renix Issue
I did say closer 31 seems a little far down the list
Old October 9th, 2017, 21:45
cruiser54's Avatar
Re: Renix Issue
The first 5 are prioritized. The rest came along in a willy nilly manor.
Old October 9th, 2017, 23:40
Re: Renix Issue
I kid, Green Jeep. I agree this one is pretty important. Will update tomorrow with results, hopefully this fixes it.
Old October 10th, 2017, 14:36
Re: Renix Issue
Well, I've done the fix, and SO FAR, it seems like a success. My throttle delay is gone, as well as my weird idle issue, bringing up an OLD weird idle issue, but I can live with that one. Here's some quick pics:
First, I disconnected the air box hose, and removed the throttle body, which were a T45 and a T30 I believe.
First the top hose
Then the bottom
The throttle body comes off after this, just remember to disconnect the two sensors, and pry off the throttle cable, a flathead works great for this, and to install just a simple set of vice grips works fine.
After that, I mounted the TB in the vise, gently as to not scratch it, and slowly tapped the MAP sensor hole, i went about 2 turns at a time until it was pretty close to seating. For reference, I used a NPT 1/8-27 tap.
Then, since I had no Permatex #2 like Cruiser suggested, I just used copper gasket maker, should be OK I suppose, would probably seal on its own anyways. Then I threaded it in and tightened it down.
Took the time to clean the throttle body again, as well as the intake surface it mounts to. Installation was the reverse, and from what I read, torque is about 15 ft lbs, so I just snugged them up, my torque wrench does not read accurately that low.
The only issues I ran into were I believe the elbows were slightly too small, and difficult to fit on, but they're definitely not going to leak air, on the upside.
Fully installed
Old cable
I hope this helps somebody else, and thank you again cruiser!
Old October 10th, 2017, 16:27
NAXJA Member #1145
Re: Renix Issue
Good work. FYI, though in a perfect world a NPT isn't supposed to require sealant, it's never a bad idea to use some. I just use RTV, the stuff you used is even better. Teflon tape can work but it's always a crapshoot in my experience.
Renix Issue!!!! JustinTurney OEM Tech Discussion 11 October 3rd, 2012 13:14
88 4L Renix cranking issue DaveVmax OEM Tech Discussion 83 March 24th, 2011 23:15
renix running issue ctxjlimited OEM Tech Discussion 7 August 30th, 2009 09:32
Renix issue? jujuscisyn OEM Tech Discussion 99 July 6th, 2009 19:27
Please help! Renix with an issue! Bensride OEM Tech Discussion 5 August 23rd, 2007 20:30
