Old September 24th, 2017, 12:46
Rumgod Rumgod is offline
Need help identifying a vacuum port
Hi, newbie here working on my jeep, it's 2000 XJ, 4.0L, 4x4, 3.5" lift, auto 180,000 miles. I've had it about 3 months and and have gone thru just about all the usual things to create a good baseline, hoses, oils, ignition, fluids, etc.
I had been aggravated with my mileage, the last thing I did was replace the upstream O2 sensor( I left downstream as it was), cleaned MAP and IAC sensors and my city mileage went from 9-11mpg to ~14.5mpg and on a controlled test(full tank of gas) run on a 60mile highway run I went from 14mpg to 21mpg at 65mph on cruise control. I'm happy now.
I do have a question though, I'm a bit of a stickler about "everything in its place" and there is a bolt stuck in the intake manifold that doesn't seem to be OEM, I can't find any pics or references to this 'port' that someone apparently blocked, maybe not stock intake manifold?!.
Can anyone help or identify this? here's a pic I took a while ago.
Thanks! -Art
Old October 7th, 2017, 09:37
Re: Need help identifying a vacuum port
still no help
Hope someone will see this and have an answer for me
Old October 7th, 2017, 09:58
RCP Phx RCP Phx is offline
It's not used on my 2000!
Old October 7th, 2017, 13:07
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
The manifold and the port are stock, and that port is always plugged. The stock plugs disintegrate.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old October 8th, 2017, 00:57
Ralph77 Ralph77 is offline
It is in use if you have a '00 with CA Emissions. Capped off if you have an '00 with Federal Emissions. Most but not all '00's came with CA Emissions. All '01's are. At least that is my understanding. Go buy something like this just to clean it up if that bugs you. They go right over the nipple on the intake manifold.
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
Old October 8th, 2017, 20:15
Heavyopp Heavyopp is offline
I have a '00 with cali emissions -- I don't think that is capped on mine -- don't know where it goes off the top of my head but I'll check tomorrow and report back
Old October 9th, 2017, 01:27
It should not be. Goes to the purge solenoid, think that is what it is called, that is in front of the blower motor in the engine compartment.
Need some quick help, vacuum port on intake machinisttx OEM Tech Discussion 4 April 26th, 2015 05:46
adding a second vacuum port to a 96+ k&n intake xj dreamin Modified Tech Discussion 1 August 12th, 2012 05:33
Vacuum port ID unclethumbtack OEM Tech Discussion 15 November 16th, 2010 23:09
Ill effects of vacuum canister removal and other vacuum/map questions? redyouch Modified Tech Discussion 38 June 26th, 2006 00:52
Doubt about Vacuum System / Vacuum accumulator schmiedel OEM Tech Discussion 6 January 2nd, 2006 08:52
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
