Old June 26th, 2017, 07:37
jmg222 jmg222 is offline
rolled my jeep.. now need help rebuilding
took the keep out this weekend-- FIRST TIME with my new lift, new wheels, new rear, new transfer case... and of course, I rolled it.
I don't know a ton about body work, even less about unibody. For a repair route, I'm thinking of getting a doner truck, having a body shop weld on a roof, swapping over whatever panels I need, and having a local shop tie in an exoskeleton to the front/rear bumpers/rock rails (haven't gotten that far along in my planning-- the exo will have to happen, just haven't planned it out)
Anyway, anyway.. set the exo aside for now... any suggestions? Is this a gonner? I've considered getting a new vehicle and swapping everything over.. but with all I've done on the motor/suspension/interior, if I can just hand this off to a body guy to fix, I'd rather do that.
ANyway.. here's the carnage:
Daily drive: 2014 Jeep Grand Cherokee SRT; stock (for now)
Trail ride: 1988 XJ: Motor/plumbing/electrical: 350 sbc, crane cam, holly performer intake, Terminator EFI, novak shorty headers, novak aluminum radiator; MSD ignition
Drive train: d30 front, F8.8 rear, 4.11 gears, np242 transfer case, rusty under-armor; fully locked with detroit lockers; Chevy 700r4 tranny, 35" MT's
Old June 26th, 2017, 08:54
RCP Phx RCP Phx is offline
Re: rolled my jeep.. now need help rebuilding
How did it happen? Where's the vid? Conditions don't look to bad!
Old June 26th, 2017, 09:01
Nealio240z's Avatar
Nealio240z Nealio240z is offline
So much for an easy break in =) I would not "hand it off to a body guy" as they will charge you more to repair it than the cost of the jeep and all the upgrades combined. I would find a donor jeep and start swapping goodies. Or cut the top off and run a cage and just beat on it...
Not sure where you live but I have 2 rolling chassis jeeps with clear papers- both are 1995.
Old June 26th, 2017, 09:16
driver error -- went up and over a nice obstacle with no problem, the exit path was a downward slope with a deceivingly high right camber, I took it too high.. just high enough... and flop.
Video was running the entire time-- unfortunetly, it was my go-pro, which was mounted to the roof.... haven't yet tried to see if it still works.
Old June 26th, 2017, 09:28
I know.. all green and blue trails all day, and then that one black obstacle I had to try...
When you say get new chassis vehicle and swap, you mean from my current Cherokee to the new chassis or the other way around? I'd rather weld a new roof on to my current jeep, than switch over the motor, transmission, lift, differnetials, and every other thing I've put into it over the years...
Old June 26th, 2017, 09:30
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
I want to be the first one in with, "cut off the top and cage it."
I'll see myself out.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
SoCal Chapter VP
Old June 26th, 2017, 09:57
Nealio240z's Avatar
Sounds Like you already know what you want to do.
Old June 26th, 2017, 09:59
smokeyyank's Avatar
smokeyyank smokeyyank is offline
That amount of body work needed to make that work isn't worth it. So IMHO you got 2 choices.
Chop it, cage it and make a buggy
or
Strip it and bolt the parts to a new rig
Old June 26th, 2017, 10:00
I don't -- I didn't mean to make that sound definitive. That's what I'm thinking of doing, but this is completely new territory for me. cutting and caging isn't off the table either , though I assume once I go that route I won't be able to use the truck on the road ...
Old June 26th, 2017, 11:48
on a related note -- if I decide to fix up what I have (as opposed to swapping my motor/suspension/etc into a new vehicle), what years should I look for as a donor? I think in 96 they changed the body style, correct? I assume a roof/quarter panels/etc. wouldn't work from anything 96 and newer?
Old June 26th, 2017, 13:11
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
You beat me to it.
If it doesnt need to be street legal its sawzall time if it does find a $300 donor and start swapping
Old June 26th, 2017, 13:24
Anak's Avatar
Anak Anak is offline
Mostly Harmless
What?
Did nobody read Nealio's post??
I am giving him credit for being the first one.
As to the years the body changed, '96 is the last year of the early version, '97 the first year of the late model.
That said, there are some body differences between the Renix years and the HO years, but AFAIK they are all minor things such as the header panel/grill and the roof racks.
Put me down as thinking your best bet is to get a new chassis/body and transfer things over. I will even go as far as saying that you should start with plating and a cage on the new chassis, then transfer parts over. Perhaps in the interim you can cut the roof off the old one and go topless for the summer, and call that motivation to hurry up and get the new chassis ready for the transfer before the weather changes.
Old June 26th, 2017, 14:14
smokeyyank's Avatar
98-99 for a newer body style or 93-96 for older. 97 body changed, 95 OBDII came out, 96 has some different things for the fuel system.
Old June 26th, 2017, 14:26
Nealio240z's Avatar
Originally Posted by Anak View Post
What?
put me down as thinking your best bet is to get a new chassis/body and transfer things over. I will even go as far as saying that you should start with plating and a cage on the new chassis, then transfer parts over. Perhaps in the interim you can cut the roof off the old one and go topless for the summer, and call that motivation to hurry up and get the new chassis ready for the transfer before the weather changes.
I thank you sir, -I do like the topless summer jeep idea...
Really only 2 options here and they both take work. I know what I would do- Swap it all over an build it better in the process- then learn the limits of my newly lifted xj
Old June 26th, 2017, 14:30
yeah, amen to that.
Rolled my Jeep. XJRunner SoCal Chapter 34 July 30th, 2010 00:16
Rolled my jeep JeepAddict85 South East Chapter 37 February 3rd, 2009 21:07
rolled my jeep now what rockjock Modified Tech Discussion 48 June 18th, 2007 17:06
Rebuilding a D30 outside the jeep Citat3962 OEM Tech Discussion 1 August 9th, 2005 10:55
Rolled Jeep JTBOSCO Sierra Chapter 12 March 3rd, 2005 08:00
