Old October 11th, 2017, 16:02
XJRN XJRN is offline
Jeep resurrection...need help
So my 99 has been sitting 3 years and hasn't moved. My wife had a baby, I broke the steering and it has just sat since I couldn't find myself to part with it. I really want to get it going and need some advice.
It is on FW 44/60 and the front links suck. They are radius arms and I had planned to go 3 link and actually have heims and an upper mount for it. The stock steering box didn't cut it with 37s and a spool so want to mount a ram assist too. I am looking for suggestions where to mount the ram. I think I need to move the track bar and build a straight one for clearance.
I also plan on replacing gas/fluids/battery but if there are any others suggestions for getting a sitting jeep running again they are welcome.
http://i1026.photobucket.com/albums/...n/IMG_3788.jpg
http://i1026.photobucket.com/albums/...n/IMG_3792.jpg
Old October 11th, 2017, 19:32
old_man's Avatar
old_man old_man is offline
Re: Jeep resurrection...need help
Rather than spend bucks on the 3 link, you really need to get the geometry right on the steering.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old October 11th, 2017, 22:05
tech1001 tech1001 is offline
What do you have on the steering box , is that a drop arm on the steering box because the steering link form the steering box to the right wheel needs to be in the same angle as the front end locating bar . that's what old man is saying
Old October 13th, 2017, 20:15
burntkat burntkat is offline
NAXJA Member #1145
Concur. Radius arms may not be what you want, but they are safe. Sounds like your steering isn't.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old October 15th, 2017, 06:45
I agree thus the statement about moving track bar. Looking for suggestions where and how to mount it while having room for a ram.
As far as radius arms they aren't safe for the road because the axle was out of a donor jeep and brackets aren't angled right for the arms and there is a lot of binding and pressure on the bushings causing them to fail.
Old December 11th, 2017, 12:11
Bump for more help. I need some suggestions
Flop resurrection garrett83 Advanced Fabrication and Engineering 208 November 30th, 2014 22:40
89 MJ Totalled, the Resurrection! xjtrailrider Jeep Comanche MJ (1985 - 1992) 166 November 27th, 2013 13:59
Resurrection of the Chief Maltese Chief Jeep Picture Showcase 27 May 16th, 2012 21:35
project mpg resurrection sjbond67 OEM Tech Discussion 22 June 1st, 2010 16:11
project Resurrection midtennxj Modified Tech Discussion 0 April 19th, 2010 21:04
