Old October 5th, 2017, 22:43
racer32's Avatar
racer32 racer32 is offline
Gear pattern check
Anyone have an opinion on this pattern?
Old October 5th, 2017, 23:09
clydefrog's Avatar
clydefrog clydefrog is offline
Re: Gear pattern check
It looks as if your not putting tension on the pinion while running the pattern with paint. Pretty vague pattern. However I did look at it pretty close, it seems as though the pinion is 'slightly' deep. Maybe back it off a tad. Ring gear looks spot on.
I would wrap a rag around the pinion and have someone hold it to put tension on it. before doing any adjustments, and re-run the paint to see where your at.
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old October 5th, 2017, 23:23
racer32's Avatar
Thanks for the quick reply and assessment. It is a bit light. I did my best to get the pattern to show up. I always put drag on the carrier but maybe that is wrong. I'll try it on the pinion. I'll make another adjustment and run it again tomorrow.
Old October 6th, 2017, 00:16
md21722 md21722 is offline
I don't see any pictures....
Old October 6th, 2017, 00:51
racer32's Avatar
How about these?
Old October 6th, 2017, 09:25
burntkat burntkat is offline
NAXJA Member #1145
I'm still learning, but those look pretty good from what I see.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Next: finish front, build rear bumpers, Dana 44's front and rear.
-94 ZJ: Budget boost, 31's. The wife's mall crawler. She's gotten inchitis over my S10 though...
-97 XJ: Son's DD. 4" lift, ACOS, completely new suspension with upgrades.
Old October 6th, 2017, 12:42
It probably won't make any noise but its too deep. Remove pinion depth shims.
Old October 6th, 2017, 12:56
trippled trippled is offline
I thought the same.
Old October 6th, 2017, 22:46
clydefrog's Avatar
Yep.
It will prob work but is still slightly deep (pinion). If its still apart, wouldn't hurt removing a few thousands on the shims.
D30 gear pattern check please kaden. Modified Tech Discussion 28 January 25th, 2013 11:17
D30 gear pattern check, first gear install P1atinum Modified Tech Discussion 19 April 7th, 2011 16:19
Gear pattern check - Please? Israel Modified Tech Discussion 13 May 27th, 2010 18:25
Check my gear pattern, please Daedalus454 Modified Tech Discussion 7 June 6th, 2008 14:24
Gear guru's...gear pattern check... freerider15 Modified Tech Discussion 21 November 21st, 2007 20:21
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
