Old September 12th, 2017, 09:43
steve1973 steve1973 is offline
CPS Opinion
I recently refreshed a 98 XJ Sport that my twin girls to drive as their first car. 177K miles, 4.0L, Auto, 4WD, stock. The only time this will see 4WD is when it snows. My goals are safety and reliability. I have tried to do as much PM work as possible to avoid any breakdowns. All fluids, rear bearings, brakes, cleaned fuel injectors, new gaskets, various electrical sensors, plugs, wires, Bilstein shocks,etc. It runs and drives like a new car. The only thing i haven't pre-emptively replaced is the CPS. I have a new one sitting in a box from Standard Products as i haven't been able to find a genuine Mopar one.
My question is, with 177K on the odometer, should I replace the perfectly good CPS with a new one from Standard. I do not know the history of the one in their now, or what make, but i would assume it is original as most other parts i have replaced have been.
Thanks
Old September 12th, 2017, 10:04
old_man's Avatar
old_man old_man is offline
Re: CPS Opinion
If it ain't broke, don't fix it. Do put the spare under the back seat.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old September 12th, 2017, 10:28
need-a-bow's Avatar
need-a-bow need-a-bow is offline
Re: CPS Opinion
Along with 2 to 3 feet of extensions and a wobble socket
Sent from my SM-G955U1 using Tapatalk
Old September 12th, 2017, 11:08
blakews2217 blakews2217 is offline
CPS Opinion
All good advice. It's one of the bigger PITA that jeeps have when it comes to sensors. Have you done anything with a tuneup? Plugs/wires/cap/rotor?
Old September 12th, 2017, 13:24
Re: CPS Opinion
Thanks.
yes, Plugs, wires, cap, rotor, MAP, TPS, IAC, O2, Alternator so i have a starting baseline
Old September 12th, 2017, 14:22
need-a-bow's Avatar
Re: CPS Opinion
BTW, definitely go with Mopar on the CPS if you buy a spare
Old September 13th, 2017, 08:29
kcox506's Avatar
kcox506 kcox506 is offline
Re: CPS Opinion
x2 Ive had a lot of CPS playtime this year. Mopar is the only solution.
Ironman4x4fab Marketing Manager
2000 XJ ~4.5" '06 4.0
LP44 w/Rubi Air Locker & 8.8 ARB
231 w/ beefy stuff
second opinion fasteddieyj Modified Tech Discussion 13 May 7th, 2011 14:23
Need ya'lls opinion... Ben824 South East Chapter 7 April 19th, 2011 15:48
Looking at a 97 XJ. Can i get your opinion? johnlv6 Non-Tech / Off Topic 24 October 1st, 2005 21:50
Your opinion please.... YELLAHEEP Colorado Chapter 65 January 6th, 2005 08:19
