Old September 11th, 2017, 16:54
PavementPrincess PavementPrincess is offline
High Pinion Dana 30 Identification
Found this on Craigslist and the guy says he has no idea what year it came off of. Can you I'd it based on the numbers? I'm buying this for my 2001 4x4. Just making sure it fits.
Old September 11th, 2017, 17:01
RCP Phx RCP Phx is online now
Re: High Pinion Dana 30 Identification
If you had the entire BOM# you could tell, other wise getting a HP is the least of your concerns, I've been on my LP for 17yrs now at 5.5"!
Old September 11th, 2017, 17:58
Is the hp30 all hype? Thought it was a tad stronger as well as a big help with driveline angles?
Old September 11th, 2017, 18:40
lawsoncl lawsoncl is offline
It has 85 stamped in it, and http://www2.dana.com/expertforms/deabill.aspx shows at least the first part of the BOM you can see as an 85-87 model. So yes, HP 3.55 gears, and I think smaller u-joints than your 99. It's also 32 years old and likely rusty inside.
Pass...
Old September 11th, 2017, 18:55
It is and can, the point is "is it worth it" to change out a good axle just cause you might do damage? But I've done 17yrs of hard rock crawling with 0 issues, you decide where to spend your money?
Old September 12th, 2017, 00:14
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Is a non-disco axle, so possibly renix era from a np242 equipped vehicle. Otherwise would be at least HO era.
You could swap your current knuckles, brakes, axle shafts, and bolt it right in
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old September 12th, 2017, 09:31
ehall's Avatar
ehall ehall is offline
HP is about 20% stronger in forward gears (LP stronger in reverse), more than a tad
Driveline angles are also better
Its not make-or-break better but it is better
my '91 beater rebuild
high pinion cover on a low pinion dana 30?? bigdummy30 OEM Tech Discussion 2 April 23rd, 2013 16:57
WTB High pinion dana 30 xjcody Sierra Chapter For Sale 1 October 29th, 2012 18:51
high pinion dana 30 ring and pinion jardine InterMountain Chapter For Sale/Wanted 0 November 17th, 2009 22:19
Dana 30 High Pinion 3.55 Ring, Pinion, Carrier, & Spiders xj92 For Sale: Private Party Only. XJ ITEMS ONLY 7 February 28th, 2004 20:14
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
