Old September 4th, 2017, 09:07
@dam @dam is offline
Re: Looks like my engine is toast. Opinions on these compression #'s?
I read that if wet compression was higher than dry compression by over 10%, your rings are considered bad
Old September 4th, 2017, 09:45
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
Originally Posted by @dam View Post
Regarding mpg, it is a 5 speed and the high altitude helps (less drag), but I did spend a good portion of both those tanks going 75 with the AC on.
That makes sense, also thinner air means less fuel for the proper ratio. Forgot about your altitude.
88 MJ on 40's. 98 XJ on 35's. 98 Dodge, 52psi of boost. 94 Miata LS4. 70 Buick GS455. 01 Harley, been to 46 states. 05 KTM, 576cc. 06 Husky, girls need bikes too. 2011 R6, girls need sport bikes too. 99 Toyota Avalon, daily. 97 Miata, girls apparently need miatas too.
And everything fits in the garage!
Originally Posted by mako my day View Post
Johnx is #1
Old September 5th, 2017, 21:27
Afireinside Afireinside is offline
That actually looks pretty good!
Old September 6th, 2017, 21:17
BCKNBLK's Avatar
BCKNBLK BCKNBLK is offline
Nothing wrong with those numbers at all. Drive it.
Old September 7th, 2017, 09:41
denverd1 denverd1 is offline
what I was thinking since wet #s were quite a bit higher. I wouldn't say bad, just got a few miles on them. get a lot of blow by?
still wouldn't be afraid to drive it like I stole it
Old September 10th, 2017, 18:58
old_man's Avatar
old_man old_man is offline
Double check your distributor indexing. It can be off in the direction that causes problems at real low rpms as well as off in a direction that causes problems at higher rpms.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old September 12th, 2017, 18:28
Jeff-97XJ's Avatar
Jeff-97XJ Jeff-97XJ is offline
Where can I get the 4 hole injectors for a 97, 4.0?
Thanks,
I just got back from a 2 tank road trip...rural highways in New Mexico. I got 23.2 and 25 mpg- my best ever. I don't get why my mpg is so good if my wet vs dry compression numbers are so different.
I'd love to drive the wheels off it, but if I can't get it by emissions without a rebuild, I might buy something more comfortable and with modern safety features like ABS. A stroker with a higher compression ratio to make up for the altitude would be fun though.
Oh yeah- the following are brand new
4-hole injectors
Cap, rotor, wires, plugs
The actual complete distributor. Old one had a little play in it so I thought it might be the cause of my miss, but it didn't make a difference
It has quicker starts and better throttle response now (and apparently REALLY good mpg), but I took it to an emissions bay and there was no improvement in the emissions at idle- like 500 ppm at idle and 180 is the limit (which I squeaked pass by revving it way up to heat up the cat just before the test)
IAC motor is a year old. Old one was fine. I also ran a can of mopar combustion chamber cleaner through before I did the emissions test and compression test.
Got about 100k on the cat, but I doubt the cat is causing the miss
Oh yeah- fuel pressure is 33 psi and oil pressure is about 45
opinions on engine cage DualPurposeXJ Modified Tech Discussion 13 July 26th, 2013 11:43
97 Xj Engine Knock, looking for opinions? Eric96Xj OEM Tech Discussion 7 February 16th, 2012 19:54
Rebuild or swap out engine - opinions please! Nixt OEM Tech Discussion 8 November 7th, 2007 21:45
Opinions on integrating suspension compression winches WheelinJR Advanced Fabrication and Engineering 19 May 9th, 2007 08:17
booster q? and engine q? opinions please tkjeeper Modified Tech Discussion 2 March 1st, 2007 18:13
