Old September 8th, 2017, 07:17
Top Heavy Top Heavy is offline
Floor Pan Pre-1997 vs 1997+
I am currently building a 1996 Cherokee Country, and would like to add Weathertech floor mats front and rear (always have, and I like the brand). Living in Canada this helps greatly with keeping moisture and salt off of the inside of the floor pans.
I have searched everywhere for this answer, though cannot find a confirmed and defined result. The seat mounting of my 1996 appears to be exactly the same as a 1997, the floor pan numbers even crossover.
Though when I look at Weathertech's website and contact customer service they do not show a listing and state there must have been a change in the floor pan or seat mounting to create a discrepancy in fit 1997 and up.
Am I missing something or are the floorpans and seatmounts as installed i a 1996 Cherokee the same as a 1997?
Old September 8th, 2017, 07:40
Anak's Avatar
Anak Anak is offline
Mostly Harmless
Re: Floor Pan Pre-1997 vs 1997+
I don't think most aftermarket manufacturers are able to distinguish between tail lights and airbags. I have found that at least one carpet manufacturer couldn't get this right.
The floor pan layout/seat mounting cut-off is 1994/1995.
In 1995 they added the airbags. Along with this they added the cross bar for seat mounting. This puts the front seat mount bolts in at an angle such that they would need to shear off, not just pull out of the sheet metal.
Pretend you have a 1997 and you should be fine.
Old September 8th, 2017, 17:22
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Consider looking into Hexomats by Introtech. Have some un my DD honda and my MJ. Will be buying a set for my XJ.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old September 12th, 2017, 09:41
asymptonic asymptonic is offline
Pricey, but I love these for my '98. Deep, easy to clean and branded, if that's your thing:
https://www.quadratec.com/products/14060_815.htm
edit: crap, they don't make them anymore I guess.
1997+ Gas tank on pre 1997 cherokee? pwnedbygary Modified Tech Discussion 24 July 31st, 2016 03:08
1997 ZJ Seats in 1997 XJ kndrewa Modified Tech Discussion 28 June 14th, 2016 08:57
1997 Xj Help clark40 OEM Tech Discussion 21 October 12th, 2015 21:10
1997 ZJ FS or FT tharlanjr SoCal For Sale 13 June 19th, 2009 17:46
1997 XJ FS (red) OnorOffroad SEC For Sale / Wanted Forum 15 December 14th, 2008 17:38
