Old April 11th, 2018, 12:03
Precious88xj Precious88xj is offline
Renix Return fuel line leak at the metal crimp end
My jeep xj is leaking fuel at the return line starting at the crimped fuel end right at the end of the fuel rail line. I cant find a replacement so I was wondering what others have done in this situation. Let me know if your suggestion is based on how you solved the problem or how you think itll be solved thanks in advance .
What im considering to fix is a rubber fuel line with a hose clamp but idk how safe that will be.
Old April 13th, 2018, 02:20
tech1001 tech1001 is offline
Re: Renix Return fuel line leak at the metal crimp end
How about a picture to see what your talking about .
Old April 13th, 2018, 06:07
cruiser54's Avatar
cruiser54 cruiser54 is offline
I can visualize that. Good description.
You're gonna have to do a splice. Use high quality fuel line intended for fuel injection systems. Use 2 hose clamps at each end.
Old April 13th, 2018, 19:52
Runnin'OnEmpty's Avatar
Runnin'OnEmpty Runnin'OnEmpty is offline
Use SAE 30R9 rated fuel hose (or 30R10 for submerged use). This is a higher grade hose than what I found connecting the fuel filter on my 96 from the factory, so Jeep considers it safe.
Old April 13th, 2018, 22:19
Hypoid's Avatar
Hypoid Hypoid is offline
I did something like that over ten years ago: Cut the factory crimp, trimmed the factory hose back about an inch, installed two "aircraft" style hose clamps to secure the hose. So far, so good!
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old April 20th, 2018, 09:17
alright i tried to do one hose clamp and it was leaking fuel pressure. Im going to attempt as you suggested two hose clamps at each end i think thatll take care of it
Old Yesterday, 18:09
Hypoid's Avatar
Just remember to rotate one of the clamps:
Renix fuel rail return line DieselSJ OEM Tech Discussion 6 February 1st, 2016 07:58
Renix Fuel Line Leak crmerrill OEM Tech Discussion 6 May 18th, 2015 20:29
Fuel return line DK_XJ_1992 OEM Tech Discussion 2 July 29th, 2013 12:26
Fuel Return on Renix Tacedaddy OEM Tech Discussion 2 December 8th, 2011 12:46
Where to find fuel return line for 1986 Cherokee diesel ventureforth OEM Tech Discussion 1 February 24th, 2009 20:37
