Old April 10th, 2018, 11:19
DanDXJ DanDXJ is offline
Rocker switch lamp socket
1990 XJ -I have snapped the lamp sockets on the rocker switches - Rear wiper, Trans Comfort. They no longer snap into the back of the switch holder. They use a #37 bulb. Has anyone replaced these sockets? Are there any aftermarket replacements ? I am guessing they may be unique to the XJ. I do not really want to glue them in place and I expect that any at the JY will be just as brittle.
Any info will be appreciated.
Old April 10th, 2018, 13:59
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Re: Rocker switch lamp socket
How about a little rubber cement? Flexible and easy to remove later, but may be just enough to hold something small like this...
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old April 10th, 2018, 14:40
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
If you switch to led the heat wont affect the rubber cement as well.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old April 11th, 2018, 19:37
Thanks for the suggestions. I am having problems finding a #37 LED bulb with a small tip to fit inside the rocker switch holder. I may just have to stay with the regular bulb - it is only
1.3 watts.
Old April 13th, 2018, 06:34
8Mud's Avatar
8Mud 8Mud is offline
I used a toothpick and a tiny drop (or three) of super glue. The only real issue is holding it steady while the glue dries enough to hold, takes a few minutes. The next time I need to replace the bulb I just break the glue loose and repeat.
Just avoid using too much super glue.
Super glue dries faster if you sprinkle it with baking soda.
Old April 13th, 2018, 18:29
Thanks for the super glue tip. I will give it a try. Hopefully I will not glue my fingers
to the bulb holder. I will probably need someone else to sprinkle the baking soda while
I hold the rocker switch.
Old April 13th, 2018, 19:10
Alaskan89XJ's Avatar
Alaskan89XJ Alaskan89XJ is offline
Try super glue 'GEL'.., less likely to glue your fingers together, lol. GEL is easier to manage, imho, by using a flat toothpick/tool in which to swipe a small blob of it off of the dispenser tip thereby having better control in order to dab, smear onto the broken area(s). Follow the rest of 8Mud's instructions.
1989 Base RENIX XJ, 4.0,BA10/5,NP231,(200k+), no A/C, OME: 2" HD; coils, leafs, Nitro Sport shocks, T-Case spacer. KevinsOffRoad; steering box brace, HardKor Track Bar, stabilizer. JKS sway bar discos, (tossed out rear sway). Warn M8000 in ARB Kangaroo Bumper. OEM 15" steel wheels; 30X9.50 Dynapro muds, OEM 15" alloy wheels; 27" Blizzacks. Recycled oem seats. CIBIE/OSRAM head lights w/protective rock mesh guards. Replacement windshield, Rain-X wipers.
Old April 16th, 2018, 18:21
tjmotter tjmotter is offline
I spent an hour at the junkyard pulling every good connector i could find. Pretty easy to pull the wires out and replace the plastic
Old Yesterday, 12:22
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Does anyone have a new switch source link the entire switches?
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Fog lamp switch mrrbby OEM Tech Discussion 8 December 29th, 2006 09:12
Fog Lamp Switch cmeuzelaar OEM Tech Discussion 2 January 20th, 2006 12:18
Fog Lamp Switch . . . GoalPoster OEM Tech Discussion 3 November 15th, 2003 13:06
lamp socket source Tucker OEM Tech Discussion 1 July 29th, 2003 15:18
