Old April 2nd, 2018, 01:31
Interceptor429 Interceptor429 is offline
clicking noise help ...on heat to a/c.
Ive tried searching but to no avail....my heater / ac is making a v licking noise when changed from heat to cool on the dail just as ut hits the blue line clicking starts.....sny thoughts or help im new to jeeps.. thanks in advance I have a 2001 60th anniversary edition graysilver. 201,000 odometer. Runs great heats great but ....clicking is stoppi g me from.checkinh a/c ....HELP PLEASE
Old April 10th, 2018, 22:53
Re: clicking noise help ...on heat to a/c.
Anyone could this be a blend door problem and how can I fix it myself ?
Old April 11th, 2018, 19:44
JeepNoob JeepNoob is offline
It's probably the blend door actuator. First stop will be to the parts store for a Chilton repair manual. Don't bother with Haynes manuals, they're junk. I've never had to do one on an XJ, but I don't remember them being that hard to get at.
Old April 11th, 2018, 21:18
dktool dktool is offline
The clicking you are hearing is likely the A/C clutch engaging then disengaging prematurely due to low refrigerant charge.
Open the hood, put it in "click" mode and watch / listen to the A/C clutch.
Normal operation is for it to engage and remain until the pressure reaches a low point prior to the evaporator beginning to freeze, then it disengages, the pressure and evap temp rise, the clutch engages again and the cycle repeats............
The A/C temp is regulated by a pressure switch and not through a thermostat or thermistor control.
Old April 12th, 2018, 22:54
Thanks ill do that.
clicking noise jamesbtaylorjt Modified Tech Discussion 1 October 15th, 2011 20:44
Clicking Noise 2001XJ-32 Modified Tech Discussion 9 July 16th, 2009 14:45
Clicking noise jk333 OEM Tech Discussion 2 July 25th, 2008 02:47
Clicking Noise triple 4 Modified Tech Discussion 2 July 19th, 2005 21:14
clicking noise!!! 93Jeepin Modified Tech Discussion 2 August 26th, 2004 18:19
