- In the islands
I am using Rusty's fixed LCA's. One of the bushings is sliding out of the arm,... well, it has been like that for quite some time. Anyway, I am in the process of tightening up the entire front end and regear the D30 to match the gears in the rear.
What are the pros and cons of each? I think the loop for the bushings are 2". Maybe drill and tap a hole, put in a zuke and use poly bushings at the axle. I would then grease them to eliminate the squeaks and keep the rubber at the body end in an attempt to keep vibrations and road noise at a minimum.
