Old September 10th, 2017, 16:06
Blindtheft Blindtheft is offline
Front Bump Stop Hang Up
A 4-link long arm kit or drop brackets will be the most likely fix for this: https://imgur.com/l7EWhEm. Right?
Old September 10th, 2017, 16:48
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
Re: Front Bump Stop Hang Up
Yes
Old September 11th, 2017, 06:53
VAhasnoWAVES VAhasnoWAVES is offline
a cheaper option would be to shorten the upper bump and add pucks to the pad in the center of the coil spring.
a little from both sides works better than all of your bump from one side.
Old September 11th, 2017, 13:23
TRCM's Avatar
TRCM TRCM is offline
Especially for lining things up since the top & bottom would only have 1/2 of the angle where as right now, the top has all of it.
Old September 11th, 2017, 15:18
ehall's Avatar
ehall ehall is offline
need to move the axle forward a little as well, hope you bought adjustable arms
my '91 beater rebuild
Old September 11th, 2017, 15:32
techno1154's Avatar
techno1154 techno1154 is offline
X's 2. And as indicated shorten the top and add to the bottom.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old September 11th, 2017, 20:18
Smart! Thank you.
Old September 11th, 2017, 20:21
This is the RE Super-Flex Kit. The lowers were replaced, but are not adjustable unfortunately.
Old September 12th, 2017, 07:01
ive run this exact kit. fixed lowers and uppers.
when castor is properly adjusted the tire should shit centered in the wheel well at ride height. short arm geometry says that the axle will travel rearward on droop, thats just how it is. drop brackets will help, but the problem will still be there. i always chuckle when people say to push the axle forward because the axle has swung rearward on droop. personally... i would make sure the bump stops are hitting square on compression. the axle placement on bump is going to be more important that on droop.
on 31s i ran 2" of bump stop on the bottom spring pad. on 35s i run 4". trim the top bump depending on your fender trimming. trimming the top should keep the coil from hanging up like in the video.
T and J front bump stop kit dirtbagXJ2103 SoCal For Sale 10 May 5th, 2010 09:55
how much do i need to bump stop my front? MaxxXJ Modified Tech Discussion 21 December 9th, 2009 22:24
Front bump stop help EFR98XJ Modified Tech Discussion 7 March 15th, 2009 00:19
My XJ has a loose front bump stop 90Pioneer Modified Tech Discussion 2 May 1st, 2007 17:25
Front bump stop issues... Brendon001 Modified Tech Discussion 19 August 16th, 2005 14:22
