Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old September 5th, 2017, 22:10
amsuco amsuco is offline
Military Style Battery Clamp Question
Hey Guys,
I've been lurking for a long time on this site and learned a lot. Now I've joined and have a question. I'm waiting on a set of Mean Lemons cables. I also need a new battery. Conventional wisdom had me looking for a dual terminal AGM battery. But if I'm switching to military style battery clamps, is there really going to be a benefit to having the DT, or should I just plan on hooking everything up to the top posts? My 1990 Comanche is stock right now. I just want to make sure it's set up for any changes I make down the road, like a possible winch addition. Thanks!
Old September 6th, 2017, 06:23
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Re: Military Style Battery Clamp Question
In my opinion there is always a need for easy battery hook ups. Especially if you plan on running a winch.
Old September 6th, 2017, 08:32
Kittrell's Avatar
Kittrell Kittrell is offline
No reason to not have the dual setup, it's there if you need it.
https://batteryguys.com/collections/...-nsb-agm-34-78
Old September 6th, 2017, 08:46
old_man's Avatar
old_man old_man is offline
Beware. The side terminals can't handle as much current as the top posts. If you are going to run a winch, only connect to the top posts.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old September 6th, 2017, 18:35
Good point about the winch needing to go to the top post. The military style clamp on the top post will also be where my cable to the starter goes as well. So if both of those are going to the top post, that's what got me wondering what use I'm still going to have for side terminals. I'm hoping to get some input from somebody who is currently running the military style clamps and see what they think.
Old September 6th, 2017, 18:42
trippled trippled is offline
I have mil style clamps. You can add a ton of stuff to them. They work great. I have a dt battery too. I have no use for the side post, but back when I bought them they were a higher CCA battery. Not sure if that still holds true but I get batteries thrubwork for cheap so not a huge deal for me.
Old September 6th, 2017, 20:30
Heavyopp Heavyopp is offline
regarding Military style clamps -- Where are you guys buying quality ones?
Old September 6th, 2017, 21:01
Jeep Driver Jeep Driver is offline
The brass parts store one work just as well.
Old September 6th, 2017, 22:49
The ones I plan on using are coming with my cable set from:
meanlemons.com
Neal participates on this site as XJwonders
Old September 7th, 2017, 05:46
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
I use the side terminals as a dedicated power source for the CB radio,fuse at the battery and QD plug inside. Just un-plug and remove.
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old September 7th, 2017, 06:37
Anak's Avatar
Anak Anak is online now
Mostly Harmless
I have gotten mine from Waytek, but Prime 4x4 is a supporting vendor and they have them too.
I have dual terminals, but I don't bother to use the side terminals. I don't care for the side terminals.
Old September 7th, 2017, 07:15
Tbone289's Avatar
Tbone289 Tbone289 is offline
I have the marine brass type battery clamps like Jeep Driver above, but don't have anything but battery cables connected to them. I prefer to use a bus bar from the PDC for accessories rather than the battery connections, but I'm not sure if that is possible with the PDC in the '90 model. There's no point in having dual terminals if you do it this way, and keeps the wiring much less cluttered.
Old September 7th, 2017, 07:26
Is there some sort of supporting vendor list here on ?
Old September 7th, 2017, 09:39
volumeknob volumeknob is offline
I bought these and was very happy with them: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old September 7th, 2017, 10:15
NAXJA Member 4950
http://sponsorship.naxja.org
As far as i know and not all vendors are on it (quadratec, meanlemons, as examples)
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
JonnyCat63
Movie military question H8PVMT Non-Tech / Off Topic 20 August 10th, 2011 09:49
XJ recovery military style onetallmj Non-Tech / Off Topic 10 June 25th, 2008 09:41
Performance Distributors - Blue, Cap and Rotor Kit GM V8 '81-'86 L- Clamp Style Hammered Non-Jeeps Items go here. 0 April 26th, 2008 15:45
ebrake cable clamp question? villestrip Modified Tech Discussion 5 December 15th, 2004 21:21
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
