Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old September 4th, 2017, 10:10
fallacist fallacist is offline
HD Shackle Relocation brackets rubbing
I installed no lift shackle relo brackets and I'm having some clearance issues. I got the no lift because I already have a bit of rake, so I was hoping to lose a half inch if anything.
My 1" Zone boomerang shackles, and they are rubbing on the inside against the new brackets. I'm not sure if they're bottoming out too, I just hear knocking sound coming from back over very minor bumps (think turning in and out of driveways and parking lots) and I can see where the shackle is scraping. I chopped off a bit of outside of the brackets, but still rubbing on the inside.
I think my angle is solid, the ride feels great, there's definitely improvement there, but I'm hesitant to use a bottom hole- which I'm sure will give me the clearance I need- since I don't want to add any lift. Suggestions?
Angle:
Another angle (Some rubbing on the outside):
Rubbing:
Old September 4th, 2017, 18:15
TRCM's Avatar
TRCM TRCM is offline
Re: HD Shackle Relocation brackets rubbing
Are those frame bolts tight ?? They don't look it...................
Is there enough clearance between the shackle & the bracket to put 2 thin washers in to space the bracket apart/out some ? (1 on each side of the shackle)
Old September 4th, 2017, 21:08
Yeah, they don't look tight in the photos, but they are. I never thought about adding a spacer in between the brackets- could that inhibit the shackle from moving freely as well? I tried bending out the brackets a bit, but they're pretty burly.
Old September 4th, 2017, 21:56
cwyman6 cwyman6 is offline
Either shim or trim that corner off if that is all that is rubbing. The two sets i have installed i run them on the bottom hole furthest rearward or one hole forward. This gave same height with better angle
Old September 5th, 2017, 20:30
MG2000XJ's Avatar
MG2000XJ MG2000XJ is offline
This ^^^. I'd play with different mounting locations/shackle angles on that relocation bracket, drop the shackle to the lower level of holes. Could always run it down some rough roads and let it self clearance. Looks like it's halfway there already. Then get some grease in there so it doesn't squeak.
Old September 5th, 2017, 23:10
Most of the rubbing is on the inside of the bracket. Nothing really to cut off there. I don't want to gain any lift from these, which is why I was hoping to avoid the bottom holes.
Ridden it around a bit, it clears, but just makes a loud knock/clunking sounds every time it does it. This just seems like an odd problem to have. Why have the upper holes if they're just going to contribute to rubbing? Am I the only one who has this problem?(Which is typical) I know the obvious solution is to use the bottom holes, but the whole point of ordering No Lift shackles was to not have a lift.
Old September 6th, 2017, 12:32
typerr typerr is offline
HD Offroad makes a great product and I have the same no-lift brackets on my XJ as well but I did end up exchanging one bracket because it was bent too tight to fit my shackles. Is it possible you just have a poor fit or the shackle bolt is not drilled straight causing the shackle to rub. Rather than post here I would first contact HD Offroad. I found their customer service to be awesome!
Old September 6th, 2017, 14:46
dan1977p's Avatar
dan1977p dan1977p is offline
No more than the brackets themselves right now. You could replace the sleeve inside the bushing as well with something a hair longer as well, but washers are a common fix for this type of issue.
91 Sport 4.0L, aw4, np231, 4.5" long arm, 33" BFG AT KO's - SOLD
SeXJ Build Thread
Old September 6th, 2017, 17:54
vt98xj vt98xj is offline
looks like the relocation bracket is twisted because it is installed on top of the hitch... try swapping the hitch and the brackets.
Andy
-98 XJ 4.5" long-arm, 35" STT Pro, D44 swap front and rear, hybrid cage, 2x6 rockers and much more
-00 XJ stock daily budget boost and rear locker
Old September 6th, 2017, 18:52
TRCM's Avatar
I see what you are saying, but the kit is made to be able to install as he did (they give you spacers to drop the top part of the bracket down as much as the hitch drops the bottom).
Old September 10th, 2017, 12:28
Blindtheft Blindtheft is offline
I'm going through the same thing - really don't want more height in the rear. No choice but to drop down to the bottom row though as I have you beat handily on the rubbing:
Old September 10th, 2017, 15:32
TRCM's Avatar
Those don't even look like shackles made for a jeep the way the ends are bent in.
They are just too wide.
Old September 11th, 2017, 08:32
donthelegend donthelegend is offline
Those are Boostwerks comp shackles, they've got a flex joint instead of a bushing. I'm running the same shackles and relocation brackets on my jeep and haven't noticed any rubbing, will go take a closer look when I get home to see if I notice anything different.
Old September 11th, 2017, 09:26
VAhasnoWAVES VAhasnoWAVES is offline
the whole point of the boostwerk shackles is to allow the shackle to misalign. bushings in a normal shackle are constantly fighting this misalignment.
you do have another option... trim or grind away where it rubs.
Old September 11th, 2017, 09:40
Ironmanandy's Avatar
Ironmanandy Ironmanandy is offline
NAXJA Supporting Vendor
These may or may not help you, but they have a narrower profile which can help with clearance issues.
https://www.ironman4x4fab.com/produc...table-shackles
'Like' us on Facebook for future discounts! Click Here
Ironman4x4Fab.com or call 704-796-3502
ECORS Class A #121 - the Black 5.9 Grand
Shackle relocation brackets jeeptec Modified Tech Discussion 9 March 2nd, 2015 18:15
Fs hd shackle relocation brackets Tobyxj InterMountain Chapter For Sale/Wanted 0 February 23rd, 2014 08:29
Shackle relocation brackets!! YAY! BRIANHO13 NAXJA Vendors Info and Feedback Forum 175 July 5th, 2011 23:55
WTB shackle relocation brackets crazymoose1990 Sierra Chapter For Sale 2 October 1st, 2010 11:52
shackle relocation brackets? rockin ron Colorado For Sale/Wanted Forum 0 January 22nd, 2010 05:38
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
