Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old September 1st, 2017, 06:36
Nimrod's Avatar
Nimrod Nimrod is offline
Livin' the dream
A probably-stupid tire question
I've long wanted to move up from 33 to 35-inch tires. But storing a 35" spare would be a problem for me. I'm running a selectable Ox locker up front and a Detroit Eaton in the rear. What would happen if i ever had to throw on a 33" spare with a set of 35" tires? I'd imagine that putting an odd size tire in front, even as a temporary measure, would cause a problem with steering. But what would be the effect of throwing the odd tire onto the rear with an auto locker? Anyone done it?
Any thoughts, as soon as possible because a deal has come up on some tires, would be much appreciated!
A whole lotta things that I never done. But I ain't never had too much fun!
Bill Kirchen and Billy C. Farlow, as recorded by Commander Cody and his Lost Planet Airmen
Old September 1st, 2017, 07:03
denverd1 denverd1 is offline
Re: A probably-stupid tire question
can't run odd size tires in the back with the auto locker. could put spare on front and make sure you don't engage the locker.
obviously, best bet would be same size tires...
Old September 1st, 2017, 07:07
Nimrod's Avatar
Livin' the dream
Cal was polite enough to PM me and tell me back-channel what a stupid question this was. Lol!
Anyway, thanks. I've got my answer. Gonna pass on the tire upgrade for now.
Old September 1st, 2017, 09:12
dan1977p's Avatar
dan1977p dan1977p is offline
If you modified the rear seat back brackets and shifted the back forward 2-4 inches, you'd have enough room to lay a 35 down in the back and still have a rear seat. Or you could modify the back of the seat by putting a tire sized divot in the middle allowing the tire to slide into the seatback while the tire is flat.
91 Sport 4.0L, aw4, np231, 4.5" long arm, 33" BFG AT KO's - SOLD
SeXJ Build Thread
Old September 1st, 2017, 09:28
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Hah. Literally what I said in my PM.
One of the locals and old school naxja member had done exactly that.
Old September 1st, 2017, 09:37
dan1977p's Avatar
LOL. I'm just trying to push the projects I wish I would have done on someone else.
Got any pics? I'd like to see how it turned out.
SeXJ Build Thread
Old September 1st, 2017, 09:43
cal's Avatar
cal cal is offline
I don't, it was like 10-12 years ago.
Old September 1st, 2017, 10:46
Nimrod's Avatar
Livin' the dream
I like the idea of making a cut-out in the back seat to accommodate the bigger tire. I've got my 33x12.5 spare laying flat in the cargo compartment now, with a tray on top to hold ice chests and bins and stuff. I'll add this mod to the bottom of my very, very long to-do list, and will shoot for getting it done and upgrading to 35s before Moab next October.
Old September 1st, 2017, 10:57
Nimrod's Avatar
Livin' the dream
I read a write-up on that some time ago, but only the top brackets of the backrest were relocated. That was to accommodate a 31 inch (if I recall correctly) tire mounted upright in the factory spare tire location. Moving just the top of the backrest forward wouldn't make space for a tire laying flat on the deck, and moving the entire seat forward two inches (including the bench and the backrest) would be a major undertaking I would think, requiring way more engineering and fabrication than it could be worth. I'd sooner just remove the back seat altogether and consider the rig forevermore a two-seater. That's my thought anyway.
Old September 1st, 2017, 11:05
Demonoid369's Avatar
Demonoid369 Demonoid369 is offline
You can fit a 33" tire in the back stock tire location, you just have to remove the step on the ground that help the smaller stock tire and deflate the spare down to 10-15 psi. That was what I did till I got a tire carrier on the bumper.
At about 10 psi you could latch the back seat no problem but anymore and you might want to relocate the larch bracket on the body.
35" you can lay on the ground but it's always easier if the tire is deflated a bit for squishing
Old September 3rd, 2017, 12:43
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
35 will fit standing up, that's where mine is temporarily until I finish my rear bumper.
Downside is blocks visibility, and tie down points aren't convenient.
88 MJ on 40's. 98 XJ on 35's. 98 Dodge, 52psi of boost. 94 Miata LS4. 70 Buick GS455. 01 Harley, been to 46 states. 05 KTM, 576cc. 06 Husky, girls need bikes too. 2011 R6, girls need sport bikes too. 99 Toyota Avalon, daily. 97 Miata, girls apparently need miatas too.
And everything fits in the garage!
Originally Posted by mako my day View Post
Johnx is #1
Old September 3rd, 2017, 16:35
MDXJ's Avatar
MDXJ MDXJ is offline
I pulled a vacuum on my 35 and made it square.The back seat still works.
90 xj 8 inches dana 44 locked tera50 locked 35x12.50x15 sye oba 95 yj stock 86 cj7 with 283 and a T18 ON 33 97 XJ STOCK SOON TO BEEN LIKE THE 90. Now 87 mj locked long armed with tube bed
Old September 3rd, 2017, 22:03
rockclimber's Avatar
rockclimber rockclimber is offline
Associate
bad plan.
even in an open dif, the spider gears will fail rather quickly.
[cal]You're an idiot rockclimber.
[StinkyFab]RockClimber is a tool.
Old September 3rd, 2017, 22:28
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
A 33" inflated tire will fit in the stock location with a little modification.
Details here.
https://www.flickr.com/photos/lwade/...7623364828871/
Both Cherokees are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
2001 Sport, 4 " lift, 33 X 10.50 KM2, DB, R.E.-UCA, JKS-LCA, ACOS, SYE, 4.56-8.25 TruTrac-D-30-E-Locker both with alloy shafts, Hidden M8000 winch, Vanco/Sport-Trac front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old September 4th, 2017, 00:05
Mach2nh Mach2nh is offline
A 35x12.5 will fit in the back laying down. You dont need to mess with the back seat latch or hinge. Just take a good size hammer and hit the back of the seat in the area of the tire. The backing is thin steel and will dish in with only a few hits. No ugly seat holes no messing around with moving the seat or anything. Its going to feel a little funny for who ever sits in that spot but the tire fits.
Stupid tire question Tacedaddy Modified Tech Discussion 5 February 17th, 2012 16:25
Stupid tire question WraithKWK SoCal Chapter 11 April 1st, 2008 20:16
stupid tire and rim question Hemenechi Modified Tech Discussion 6 November 19th, 2007 10:31
stupid newbish tire/wheel question Ramsey Modified Tech Discussion 9 January 28th, 2006 19:52
Spare Tire Carrier & stupid hood release! xj2k Modified Tech Discussion 1 September 5th, 2003 11:13
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
