Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old September 8th, 2017, 13:57
TRCM's Avatar
TRCM TRCM is offline
Re: Front driveshaft spins in 2wd with unlocked hubs
Ok...according to the grimmreaper site, 35" tires, AW4 trans, NP231 tcase, you should be doing 81 mph @ 3000 rpm down the highway
IF you stay in 3rd gear, it should be 61 mph @ 3000 rpm
65 mph with those tires & gears should be 2400 rpm, not 3000............
Does you trans actually go into lockup & OD anymore ??
I know I had issues with mine in the past, and it didn't lockup or stay in OD, and even with 31's, I was spinning 2400 @ 65 mph
Hubs are unlocked, but tires still chirp mcantar18c Colorado Chapter 56 October 6th, 2009 14:07
242 t case with SYE installed and Spicer driveshaft adapter and front driveshaft benulis55 For Sale: Private Party Only. XJ ITEMS ONLY 1 July 28th, 2009 04:58
Driveshaft Disco instead of locking hubs.....discuss XJEEPER Modified Tech Discussion 39 October 31st, 2008 18:46
Front drive shaft spins in 2wd? NCXJMAN OEM Tech Discussion 5 January 25th, 2006 19:00
front ds always spins AZ XJ Modified Tech Discussion 11 October 26th, 2005 21:32
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
