Old August 26th, 2017, 20:51
trippled trippled is online now
Re: Front driveshaft spins in 2wd with unlocked hubs
Originally Posted by Boostwerks.com View Post
Does the front DS spin freely when not running?
I wouldn't be surprised that it would start spinning simply from the slight bearing drag of the TC.
This. It happens.
Old August 26th, 2017, 21:25
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
Originally Posted by Desert4x4 View Post
It is, but... I had angled it to perfectly straight, and the vibration was still there. The driveshaft was also rebuilt, balanced and trued, and the vibration was still there. I also replaced the transfer case, no change.
Do the vibes disappear with the DS removed?
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old August 26th, 2017, 23:40
TRCM's Avatar
TRCM TRCM is offline
Originally Posted by trippled View Post
This. It happens.
Yep..it happened on my 79 Ramcharger with a NP203 t-case, even after the part time conversion kit was installed....it's just friction.
You could reach up and stop it with your hand, then let go, and in a minute or so it'd be spinning again.
Old August 27th, 2017, 00:43
Demonoid369's Avatar
Demonoid369 Demonoid369 is offline
Sounds like the driveshaft needs better balancing possibly.
Just to clarify, you are driving in 2wd right?
Old August 27th, 2017, 06:20
ehall's Avatar
ehall ehall is offline
Make sure you can freely spin the front driveshaft by hand. After that I wouldn't worry about it. Probably surface tension from the oil film creating drag for the chain drive.
my '91 beater rebuild
Old August 27th, 2017, 08:53
Desert4x4 Desert4x4 is offline
Yes. Very smooth without the front shaft.
Yes of course. I'm using 2wd not 4FT.
Yeah I can spin it by hand no problem
Hmm ok thanks.
Old August 28th, 2017, 17:48
Jim Malcolm Jim Malcolm is offline
OEM staft? At 4" of lift with aftermarket LCAs and a 242 t-case in my 94, the measurement I gave when getting the new one was nearly 2" longer than the OEM spec. There's only 3" of travel... Smooth as butter at all speeds now after wasting money having the OEM one straightened, balanced and rebuilt.
Old August 30th, 2017, 06:14
I ordered a custom shaft. I don't remember the length. It's a long travel drive shaft.
Old September 2nd, 2017, 15:02
I used two of the thick plastic tie wraps to hold the driveshaft from spinning. So far it as worked. I've had the Jeep up to 75mph which is about the max I like to do. Problem solved, I suppose.
Old September 2nd, 2017, 15:12
TRCM's Avatar
If you have a new custom D/S in the front, and it still does it, you either have issues internal to the tcase @ the front output, or you have issues in the diff.
Either way, they need to get fixed.
Or you can do like I did for a long time in the truck in my avatar.....keep the front D/S inside the truck with all the tools to install it when needed. I did that for MPG, as it was a FT 4wd truck back then.
Old September 2nd, 2017, 21:58
chris420 chris420 is offline
I have the Warn lockouts and my driveshaft does not spin in 2WD. When the hubs are unlocked the front wheels spin on the bearing whithin the hubs. I have seen Dodge and Ford trucks with manual lock outs that have enough drag to spin the front DS very slowly but nothing fast enough to create driveline vibes. The best way to test is get underneath the jeep with all 4 tires on the ground with it in 2WD and grab the front drive shaft with 1 hand and spin it, it should spin freely if it does not then with your hubs are not working properly or your transfer case is stuck in part time or full time 4wd.
Old September 2nd, 2017, 22:02
On a second note I have a 6" lift and run stock front drive shafts with no issues. I also run stock front drive shafts in the rear with no issues. I have an NP242 TCase. You don't need a custom drive shaft stock shafts will do however you may need to change the flanges depending on your set up.
Old September 7th, 2017, 12:26
I forgot to add that I have 5.13s in this XJ. So the driveshaft speed is significantly higher than with stock gearing.
Old September 7th, 2017, 14:18
TRCM's Avatar
what size tires are you running ? may not be that much more
Old September 7th, 2017, 17:49
35x12.5r15
Yeah, well its about 3,000 rpm at 65 mph
Hubs are unlocked, but tires still chirp mcantar18c Colorado Chapter 56 October 6th, 2009 15:07
242 t case with SYE installed and Spicer driveshaft adapter and front driveshaft benulis55 For Sale: Private Party Only. XJ ITEMS ONLY 1 July 28th, 2009 05:58
Driveshaft Disco instead of locking hubs.....discuss XJEEPER Modified Tech Discussion 39 October 31st, 2008 19:46
Front drive shaft spins in 2wd? NCXJMAN OEM Tech Discussion 5 January 25th, 2006 20:00
front ds always spins AZ XJ Modified Tech Discussion 11 October 26th, 2005 22:32
