Old August 29th, 2017, 12:26
praetorian praetorian is offline
Re: Front Axle Options
Looks like the k3162 come with 4 and have a better coating on the metal.
Old August 29th, 2017, 14:55
ehall's Avatar
ehall ehall is offline
I think they changed the bushings slightly for the WJ arms--same diameters but there are nipples on the inner sleeve to prevent it from seizing to the bolt. I think.
my '91 beater rebuild
Old August 31st, 2017, 10:27
volumeknob volumeknob is offline
What brand and viscosity of diff lube should I be running?
Old August 31st, 2017, 14:01
Tbone289's Avatar
Tbone289 Tbone289 is offline
Cheapo 80w-90 is fine. 75w-90 synth if it makes you feel better, or if you feel you need "heavy duty" then 85w-140 or 75w-140 synth. Brand isn't that important.
Old August 31st, 2017, 14:30
burntkat burntkat is offline
NAXJA Member #1145
I found those same dimpled bushings inside my wife's 94ZJ last year when I did the arm upgrade.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old August 31st, 2017, 14:53
Cool, I just snagged a jug of Carquest 80W-90. Found an axle with 24K miles in a local yard. This weekend should be fun! Got all new Moog steering parts to bolt on too. Just found all the torque specs. Please correct if any of these are wrong:
Dana 30 diff cover - 30 ft/lbs
LCA to axle - 85 ft/lbs
UCA to axle - 55 ft/lbs
All TRE's - 35 ft/lbs
Adjustment sleeves - 14 ft/lbs
Shocks to axle - 17-20 ft/lbs
Driveshaft to T-case - 14 ft/lbs
Driveshaft to axle - 13-18 ft/lbs
Caliper bolts - 30 ft/lbs
Lugs - 85 ft/lbs
Steering Gear box to frame - 65 ft/lbs
I had to dig for this info so maybe it'll come in handy to someone reading this.
Old September 1st, 2017, 11:09
What would you guys do to protect this axle from further rust? Just some wash it down wit some Super Clean and then a rattle can job?
I have some of this sitting around
Been waiting for a project to try it on.
Old September 1st, 2017, 11:35
VAhasnoWAVES VAhasnoWAVES is offline
master coat
this stuff seems to last better than anything else ive done.
finish with what ever rattle can of your choice.
Old September 1st, 2017, 11:38
Originally Posted by VAhasnoWAVES View Post
master coat
Did you find it locally? Found it on their website but I'm looking to do this tonight and tomorrow morning if need be.
Old September 1st, 2017, 11:44
i ordered.
Old September 1st, 2017, 12:02
i ordered.
Right on, I'm just going to clean it up good and wire wheel the rough spots, then spray it with some Rustoleum primer and black hammered. That should work until I'm ready to build it up.
Old September 1st, 2017, 12:10
i wouldnt even waste the time waiting for paint to dry.
if you dont plan on truely prepping the metal... pressure wash it, degrease it, and go.
Tbone289's Avatar
I just spray a coat Fluid Film on a couple times a year. If there's any initial rust scale, that would be wire brushed first. I wouldn't do more than that unless I was disassembling for a build or upgrade and had time and space for proper finish prep. Fluid film does a great job of stopping corrosion.
Old September 4th, 2017, 22:09
NAXJA Member #1145
Degrease, wire wheel, OsPho. Then shoot it with Rustoleum Hammered Finish (prime and paint in one) and run it.
Old September 5th, 2017, 06:24
I got the old D30 pulled Friday night. Started fresh early Saturday morning with a wash and degrease, then ran to town for replacement shock mounting bolts and incorrect UCA bolts that the PO slapped in there. Rusty metal primed it and finished with blacked hammered. Got it in and waited overnight to fill the diff with oil. All new Moog steering parts went on good and did a driveway alignment. She purrs right along at 70 now, I wouldn't go much over 55 before.
Now I have a bumper to paint and get put on! Hopefully the steering gear box bolts don't give me any lip.
front axle swap options ? xj-krawler88 Modified Tech Discussion 10 April 10th, 2011 08:26
Pre-Made/Custom Front Axle Options? spinaldex Modified Tech Discussion 2 April 6th, 2009 22:22
Front axle options... rcmf5525 Modified Tech Discussion 19 January 22nd, 2008 16:22
Contemplating Front Axle Options FitchVA Modified Tech Discussion 12 June 9th, 2006 23:19
front axle options... allthingsoffroad Modified Tech Discussion 15 October 18th, 2005 07:50
