Old August 9th, 2014, 23:51
thatxjguy's Avatar
thatxjguy thatxjguy is offline
Re: Thatxjguy's 1999 Jeep Cherokee Build 'Hole in the Pocket'
Originally Posted by yossarian19 View Post
I like that routing and will probably do the same thing if I ever mount a bar up top. That's slick.
Thanks! I really didn't feel like drilling, so I was happy when I found a way to do it like this.
Old August 12th, 2014, 10:59
thatxjguy's Avatar
Routed it into an aftermarket connection for the factory fog light switch!
And there's my LED light bar switch:
Looks like a clean factory-installed switch!
Old August 17th, 2014, 15:00
thatxjguy's Avatar
It's a slow day today, so I added more switch spots to my factory toggle switch bezel.
A band saw and a soldering iron is all I needed:
Old August 17th, 2014, 16:47
thatxjguy's Avatar
I'm thinking it came out nicely:
Old August 17th, 2014, 17:54
Root Moose's Avatar
Root Moose Root Moose is offline
Nice touch making the multi-switch panel.
I have a factory four switch panel in that location but am thinking about cut-n-pasting factory switches into the overhead console if I can ever get to it.
Old August 17th, 2014, 18:01
thatxjguy's Avatar
I would love one of those 4-switch panels.
Old August 17th, 2014, 18:19
Root Moose's Avatar
Yeah, when I ordered mine it was one of something like five left in Chrysler's inventory. That was many moons ago... and it has been sitting in its box since then. Doing a big push to update/modernize the interior now so should get installed soon.
Old August 17th, 2014, 19:44
Hardkor Hardkor is offline
Nice build. Some good ideas in this thread, thanks. Keep building.
Old August 17th, 2014, 21:38
Hillbilly XJ's Avatar
Hillbilly XJ Hillbilly XJ is offline
Yup its a nice 'Mall Crawler" for sure really clean and Purty.
Old August 18th, 2014, 06:10
Nothing wrong with a clean rig. But I would've cut those fenders after the first time they got crunched.
Old August 19th, 2014, 20:15
thatxjguy's Avatar
Knocking SOLVED!
I rolled in a set of new rod bearings today with the engine still in the chassis (super easy with my 6.5-inch lift), and wowwwwwww, cylinder 6 was really worn:
Cylinder 3 was also pretty bad, as was cylinder 5, but the others were alright. I replaced all 6 rod bearings just to be safe.
I feel much better without any knocking. The crankshaft looked great, pistons looked great, no wrist pin movement. I'm happy!
Old August 21st, 2014, 07:13
Tony_SS's Avatar
Tony_SS Tony_SS is offline
NAXJA Supporting Vendor
Nice save! Mine looked just as bad... if the rod didn't punch a hole in the block I could've gotten away with what you just did. Nice work!
Skull Daddy Graphics for Jeep Stickers
Mac-Ink Customs
for Jeep T-Shirts
2000 XJ Build Thread
Old August 21st, 2014, 07:45
Redsnake Redsnake is offline
Rod Bearings may be the culprit in my '01 XJ... I tried searching on this forum to no avail, but would anyone have a link to the process?
My 'noises' might be piston slap or noisy lifters, but since I've had to replace my 0331 cracked head it could be a host of things.
Old August 21st, 2014, 08:28
thatxjguy's Avatar
Simply:
1. Drain your oil
2. Allow your vehicle to cool off (preferably over night)
3. Remove your oil pan (may need to unbolt exhaust from header for clearance)
4. Remove your main bearing cap brace
5. Remove rod bearing cap
6. Lightly tap a flathead screwdriver on the non-lock side of the top bearing to roll it around the crankshaft
7. Take your new bearing and grease it up with high-impact grease
8. Stick it on the crankshaft and roll it up to the top
9. Make sure the lock goes into the lock crevice, then make sure both sides of the bearing are flush with the connecting rod
10. Attach another bearing to the rod bearing cap and make sure both sides are flush and that the lock goes into the lock crevice
11. Tighten the rod bearing cap back to the connecting rod @ 33 foot pounds
12. Repeat steps 5-11 for all remaining cylinders
13. Use GUNK to clean up dirt and grime from oil pan and main bearing cap brace
14. Re-tighten main bearing cap brace to main bearing caps @35 foot pounds
15. Remove flex plate cover while there's room and inspect flex plate for cracking or loose bolts
16. Re-attach oil pan to bottom of engine with new gasket
Keep in mind that I'm lifted 6.5 inches and everything was fairly easy for me to pull out of the Jeep right from the chassis. If you're stock height, you may need to raise your Jeep 3-4 inches in the air for you to have enough clearance to remove the oil pain from the chassis, otherwise, you'll need to pull the whole motor.
Old August 21st, 2014, 08:40
Very cool! Thanks for the write-up and how-to. I'm not lifted but I have some great ramps that I use to get the ole' XJ off the ground if needed.
Is it also possible to replace the Main Bearing while doing this or do you have to remove the Cam, etc... to get at that?
1999 jeep cherokee great-white NAC Classifieds 23 April 1st, 2011 16:40
1999 Jeep Cherokee-small build joshjan NAC Classifieds 4 September 29th, 2009 19:55
1999 Jeep Cherokee Kramnden InterMountain Chapter For Sale/Wanted 14 December 14th, 2006 23:31
1999 Jeep Cherokee XJ tubbinator For Sale: Private Party Only. XJ ITEMS ONLY 2 July 2nd, 2006 22:27
I got coilover cash burning a hole in my pocket strokedwoody Modified Tech Discussion 11 May 3rd, 2004 01:23
