Old May 16th, 2014, 06:35
JeepBTDT's Avatar
JeepBTDT JeepBTDT is offline
On a Time Out
Re: Thatxjguy's 1999 Jeep Cherokee Build 'Hole in the Pocket'
Don't need the PUTCO when using the TruckLites. They are low current flow. That is one of the advantages of using the TruckLites. Sometimes water and bad relays plague the PUTCO.
Old May 16th, 2014, 08:33
thatxjguy's Avatar
thatxjguy thatxjguy is offline
That's always great to know AFTER buying it :P.
Old May 22nd, 2014, 00:16
thatxjguy's Avatar
Got a 12-inch LED light bar installed on my bumper tonight:
This bad boy puts out over 5000 lumens, and it outshines my TruckLite LED headlights. I love it.
Old May 22nd, 2014, 13:12
thatxjguy's Avatar
More pictures, this time in the light:
Old July 6th, 2014, 21:19
thatxjguy's Avatar
Finally got to that engine heat issue.
Since it was getting really bad with the engine getting hot while idling, I decided to investigate. I took off the cap of my radiator and found that there was a lot of green muddy buildup in there:
I had already bought a new thermostat for the Jeep, because the one that was in there already was staying stuck open:
After taking off the thermostat housing from the front of the engine, I tugged on the old thermostat, which was stuck open, and the whole thing just BROKE. Yeah, I think it was definitely in need of replacing:
It was pretty nasty in there:
I cleaned up the gasket area real well on both the thermostat housing and the engine head before applying a little permatex to the gasket and re-applying. Then I tightened in the new thermostat.
Now one more thing... with the thermostat replaced, and the obvious need to get all that crud out of my engine and radiator, it was time for a full flush and engine cleaning. To help with this, I installed a T connection in the top coolant line to make it all easier:
I then emptied the coolant system and filled it up with a mixture of water and oxalic acid to eat away at the crud. I ran the engine at 1500 rpms for 2 hours straight with this solution, and then drained it and added water and sodium carbonate and ran the engine for 10 minutes to neutralize the acid. Then, I flushed one more time and added all new coolant and water to finalize the process.
The Jeep is now operating at 190 degrees with a very nice idle.
Old August 7th, 2014, 21:30
thatxjguy's Avatar
50-incher came today:
Old August 8th, 2014, 22:23
thatxjguy's Avatar
Finally got that bad-boy installed!
Bright as HELL!
Old August 9th, 2014, 11:15
thatxjguy's Avatar
Closeup of the bracket and how I routed the wiring down the windshield seal down to the fender:
Didn't do any drilling!
Old August 9th, 2014, 14:14
yossarian19's Avatar
yossarian19 yossarian19 is offline
I like that routing and will probably do the same thing if I ever mount a bar up top. That's slick.
Old August 9th, 2014, 14:38
stewgod stewgod is offline
that roof light bar doesnt illuminate the hood too much *(glare?)
Old August 9th, 2014, 18:52
highspeed's Avatar
highspeed highspeed is offline
What light bars are those?
Nice build btw
Old August 9th, 2014, 20:07
chris420 chris420 is offline
I can't be leave you have bought all those lights and have not bought rock rails yet or cut your fenders. Those tires are going to smash your fenders when you hit the rocks.
Old August 9th, 2014, 23:43
thatxjguy's Avatar
Yeah, they already have. I just bend them back.
And here are some night pics:
thatxjguy's Avatar
No glare at all really. Just a white stinger bar lol.
Old August 9th, 2014, 23:46
thatxjguy's Avatar
Nice build btw
The 12-incher is Rough Country's Epistar bar. (5280 lumens)
The 50-incher is a rigid CREE bar. (29,400 lumens)
1999 jeep cherokee great-white NAC Classifieds 23 April 1st, 2011 16:40
1999 Jeep Cherokee-small build joshjan NAC Classifieds 4 September 29th, 2009 19:55
1999 Jeep Cherokee Kramnden InterMountain Chapter For Sale/Wanted 14 December 14th, 2006 23:31
1999 Jeep Cherokee XJ tubbinator For Sale: Private Party Only. XJ ITEMS ONLY 2 July 2nd, 2006 22:27
I got coilover cash burning a hole in my pocket strokedwoody Modified Tech Discussion 11 May 3rd, 2004 01:23
