Old September 11th, 2017, 22:10
Mach2nh Mach2nh is offline
Re: Double Sanden compressors!
Picked up adjustable oil foggier from HF and it seems to work really well in my 97 pump. Key things about the setup is dont use 30wt its to thick. tool oil or even atf seems to flow very well. The big one is keeping the intake size to 1/4 and no bigger. The intake has very little suction and you need to keep the air velocity up so it will carry the oil. To do this you need to keep the ID smaller but not so small it will starve the pump. You dont need much to keep the pump happy. but DO run a air take 2.5gal or better to give the pump a little bit of down time.
Old September 12th, 2017, 14:12
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
Thanks! all good things to know. I was planning to get a few hot dog compressors from h/f to cannibalize for tanks, valves, and such.
I've got a few nooks and crannies under the bed scoped out.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old November 3rd, 2017, 18:08
four_shot's Avatar
How 'bout it Gonzo
Just ordered a pair of stainless 3 gal. tanks from chassis tech. Yay!
I was planning to use a 4 pass trans cooler between the compressor and check valve, any suggestions on how to connect the aluminum discharge pipe to it. As i understand, this connection will get hot enough to melt rubber.
4shot
B double E double R un request 2010 GRIMUS99XJ WinterFest 2010 111 April 1st, 2010 06:43
sanden compressor OBA stxcherokee Modified Tech Discussion 4 July 16th, 2008 11:24
sanden compressor for OBA nickangus Modified Tech Discussion 4 August 24th, 2006 03:40
98 sanden A/C compressor RichP OEM Tech Discussion 0 May 2nd, 2004 12:56
