Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old November 4th, 2013, 21:26
bmikes's Avatar
bmikes bmikes is offline
Re: Double Sanden compressors!
Awesome write up! I might do this in the future, thanks for the info!
Old November 4th, 2013, 21:56
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
blow-by is more a result of age and condition of the engine. If you get as little as you say its more than likely not going to affect anything pro or con. Now I'm jealous. I had another sanden I was going to do this with. But I seem to have misplaced it!
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old February 2nd, 2015, 10:34
bad luck bad luck is offline
I want to do this too! A good tutorial on how to do it. BTW what kind of pliers are you using gripping that bolt head?
Old February 3rd, 2015, 06:16
shelbyluvv's Avatar
shelbyluvv shelbyluvv is offline
http://www.knipex.com/nc/en/products...l&groupID=1500
Old February 25th, 2015, 13:01
G2WANIT G2WANIT is offline
So, I'm pretty much a cheap-tool kinda guy, love me some Harbor Freight ... most of the time. I've made a few exceptions over the years - at various father's days (which coincides with my Birthday) I've had my wife get me a Craftsman mechanics tool set (all 8-point sockets) and a set of GearWrench flex combination wrenches. Those make me smile.
But those Knipex pliers I use all the time and love them. I bought both the smooth parallel jaw style and the standard channel-lock type (both in 7-inch) and just plain love them. I'd replace them again in a heartbeat.
Knipex 86 03 180:
Knipex 87 02 180:
These are the exact ones I have, and I'd pay extra for the "comfort grip" as it REALLY makes it nice when you have to clamp down hard on something.
Old February 25th, 2015, 14:17
WAZZUXJ's Avatar
WAZZUXJ WAZZUXJ is offline
Nice work! Same concept I used to run my York 210 compressor. I basically built a modified version of the Kilby Wrangler 4.0L bracket that just placed the York lower in the engine bay to clear the hood. Used to run ARB's front and rear.
York mounted beside stock A/C compressor and run on single serpentine belt.
Manifold system with pressure gauge for ARB's. One of these days I will clean this up.
Battery relocated to driverside and cold air intake installed.
Kilby 1.75g air tank mounted in cargo area.
Old June 28th, 2016, 17:03
Redxj5150's Avatar
Redxj5150 Redxj5150 is offline
I kinda want to bring this back to light and ask a question.
Why grease? Why not block off the oiler hole like it is and then run a regular motor oil in it? It wouldn't need much. I just think the grease isn't going to reach critical areas of wear whereas an oil will whip all over the place being that it is a thrash plate motor. It'll lubricate just as if it was a running AC system. Seeing as how the modification came from the minitruck realm I think I'll try oil. If it fails I'm not out very much. The JY is littered with them now.
Travis
99XJ
67Commando
Old June 29th, 2016, 10:02
four_shot's Avatar
How 'bout it Gonzo
The grease will liquify once it warms up. Or so the thought goes.
4shot
Old June 29th, 2016, 10:51
Devilfrog Devilfrog is offline
I would use a good compressor oil.
The sanden is designed to be splash oiled and most failures using grease are due to the front bearing running dry too long (the internal design has scoops and channels to aid in migrating oil into the bearing. Depending on the grease, it isn't going to liquify at all.
Then, when you replace the plug run a pipe fitting and breather on a long hose (similar to an axle breather). The Sanden service manual has the factory spec fill capacities as well. Maybe go a bit over that as it won't be as pressurized as it would in a functioning A/C system.
Sent from my SGH-I337M using Tapatalk
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
Yeah, I would probably use oil too, the bracket is an ingenious design though.
The factory setup is lubed by the oil mixed into the refrigerant charge, which is miscible (soluble in) it. That is why choosing the right refrigerant system oil is important, R12, R134a, R152a, etc refrigerants all use different oils from a few subsets, typically ester oil, PAG oil, etc.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old June 29th, 2016, 16:36
Redxj5150's Avatar
What i've gathered is that it's around 2.5 oz. The breather sounds like a good idea also since the mechanical side is sealed off from the suction side by way of the plug.
Travis
99XJ
67Commando
Old June 30th, 2016, 07:37
four_shot's Avatar
How 'bout it Gonzo
The sanden is designed to be splash oiled and most failures using grease are due to the front bearing running dry too long (the internal design has scoops and channels to aid in migrating oil into the bearing. )
Good to know! I'll be giving this a long look when it comes time to start my build.
4shot
Old September 10th, 2017, 20:11
four_shot's Avatar
How 'bout it Gonzo
Is there a long term status update? I'm about to start building the oba on my pickup.
4shot
Old September 11th, 2017, 11:43
stockerwithalocker's Avatar
stockerwithalocker stockerwithalocker is offline
Got Shafted
I personally use an inline oiler. I -refill it with 3 N 1 oil when the oiler is dry and my compressor has been going strong for 7-8 years now.
Old September 11th, 2017, 18:52
four_shot's Avatar
How 'bout it Gonzo
I plan on doing the oiler. I'm not very confident in the grease mod. I'm thinking I'll use straight 30w.
4shot
B double E double R un request 2010 GRIMUS99XJ WinterFest 2010 111 April 1st, 2010 05:43
sanden compressor OBA stxcherokee Modified Tech Discussion 4 July 16th, 2008 10:24
sanden compressor for OBA nickangus Modified Tech Discussion 4 August 24th, 2006 02:40
98 sanden A/C compressor RichP OEM Tech Discussion 0 May 2nd, 2004 11:56
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
