MichaelMaxim
- Woodbridge, VA
I bought a 1997 XJ with 190xxx miles on it two summers with the intentions of building a serious trail rig. I wanted something I could pay cash for and then build as I go. I used to have a 2001 TJ that we owed a lot on and I dumped 8k into it with the lift, suspension, winch, bumpers, sliders, yada yada yada only to sell it a year later for what I owed on it. Didn't want to make that mistake again...
So here it goes.
This is the rig as I bought it stock a two summers ago.
Here's how it sits now...
Parts List to Date:
- (1) Rusty's 8" Hi-Clearance Long Arm Lift Kit
- Rusty's Builder Fab Coil Buckets
- Rusty's Builder Fab Lower Control Arm Mounts
- Rusty's Builder Fab Universal Shock Mounts
- (2) Dana 44 LP axles out of 89 Wagoneer (front and rear)
- TSM Disc Brake Conversion Kit for Dana 44 for rear axle
- New front rotors, pads and calipers
- Extended braided steel brake lines in all four corners
- (5) 36x13.50 R15 Irok tires
- (5) 15x10 with 6 lug Crager Soft 8 steel wheels
- (1) NP231J 23 spline transfer case
- Tom Woods drive shafts
- TeraLow 4:1 Kit
- TeraLow 2LO kit
- 23 Spline AW4 Auto transmission
- Aluminum Novak Shifter
- (2) Ox Lockers for Dana 44 for front and rear with aluminum shifters
- (2) 100 inch Ox Locker Cables
- (2) Yukon 4.88 ring and pinion sets
- (2) Yukon master install kits for gears
- (4) Bilstein 5150 12" travel remote resevoir shocks
- New Water pump from Advanced Auto Parts
- Rockhard 4x4 rear bumper with tire carrier
- AJ's Offroad Armor super rock rail sliders
- Custom built stinger winch front bumper
- Skidrow modified gas tank skid
- Custom 1.25 DOM .360 wall, Steering by 505 Performance with 5/8th rod-ends and heim joints
- Husky Liner Molded Floor Mats, Front, Rear and Cargo Area
- Tom Woods Super Flex 1310 u-joint for front drive shaft (adds 10* of flex)
Future Plans Include:
- Roll Cage
- Super Winch EPI 9.0 Winch
- New Seats with 5 point Harnesses
- On Board Air
- Ready Welder
- Sound System
- Latch Down System for spare axle shafts
- Tube Fenders
Tools that I've picked up so far to assist in the build:
- Miller 180 MIG welder
- JD2 Model 3 Tube Bender
- Harbor Frieght Tube Notcher
- Harbor Freight electric band saw
- 2 Ryobi Grinders (one with a cutoff wheel, one with a sanding pad)
So here it goes.
Parts List to Date:
- TeraLow 4:1 Kit
- TeraLow 2LO kit
- Roll Cage
- On Board Air
- Ready Welder
- Sound System
- Tube Fenders
