2000 Aw4 transmission gray plug smashed. Help finding replacement
SofaKing
Wisconsin
I was moving the transmission getting ready to put it under the xj and set it down on the gray 8 pin plug that uses 7 wires. It connects the transmission to the main wiring harness by the firewall. Does any body know where I can buy a replacement plug? If so part numbers would help too.
Thanks
Sounds like the main wiring plug. I don't know of a source other than robbing from another xj.
I haven't found any replacement harness for sale.
The only place you will find one is a pull a part or junk yard I believe.
