Project_reaper
- new jersey
Ok so I know there's alot of questions/post about trans problems. But my issue seems that no has encountered it yet.
Long story short bought a 98 that needed a trans no reverse. Got a trans from a buddy out of an 01. Same trans same plug styles but the main trans harness was cut when it was pulled from his parts xj. Pulling the bad trans out of the 98 was just a nightmare someone was in there things wherent tight and stuff was broken. The main thing that I was concerned about was the black plug that gose in the side of the trans for the solenoids was broken and just sitting there. Didnt want want any problems, so I put the word out for a trans harness and someone answered. Said I could have the harness for nothing but I had to pull it out of the jeep not a big deal so I did. (FYI the trans harness is from an 99 or 01
Got everything back together up and running drives good nice and smooth shift are a little late but I figure it was from the tps code that was originally stored in the history from when I bought the jeep. Ran over to the parts store picked up a new, at this point everything is perfect and thinking to my self man this is the easiest 500.00 bucs I ever spent haha. Well on my way to work this morning the jeep dies at a light.
Bring my scanner home thinking ok maybe the crank sensor took a shit since it didn't want to restart after it died. Go into engine codes with my soulus and find a trans fault code( oh boy great). Go into the tcm and pull up codes and long behold a tps is in there. P0123. Go into data now to see if tps voltage is right. This is what I have.
Idle: .6 to 1.0v is normal
Actual 0.0v at idle
WOT: 3.5 to 4.0v normal
Actual: 11.0v
Yes I did a wiggle test while watching the scanner to see if anything jumps did not notice anything. My question is, is the 99-01 trans harness compliant with the 98? I figured it would be since they are pretty much identical drive train wise.
Hope I filled in enough info for you guys thanks
Sent from my SM-G925P using Tapatalk
Actual 0.0v at idle
Actual: 11.0v
