Front axle off center even with trackbar unhooked
viperbluelx
Ringgold, GA
I have a 92 with a RC 4.5" short arm lift. When I got it I noticed that the axle was offset approximately 1" to the driver side. It has an aftermarket bracket on the axle end. Anyway I assumed I needed an adjustable track bar so I ordered one. I remove the stock track bar today and much to my surprise there was no pre-load on the bar. After removing the stock bar the axle was still offset to the driver side and you can even see it in the coil springs being tilted. The only way I could get it centered was to put some pretty good pre-load on the adjustable track bar, but that doesn't seem right to me? Any idea?
get someone to sit in the drivers seat have them turn the steering wheel till frt of jeep is centerd, then install adj trackbar
