asatxj
- Grant, Michigan
Finally changed the trans mount boy that was junked! The improvement is great, my xcase shifting problem is gone now! arty:
But..... I stripped one of the nuts inside the rail when reinstalling the xmember. I can think of 2 choices
1. cut a hole in rail, put wrench on nut tighten, reweld hole
2. use a BIG tek screw (called a Tek 5 for attaching finish panels to steel I beams in construction.) for additional security. About same size as stud I stripped.
Opinions?
Opinions?
