Tach wire
clean96XJ
CT
Okay, maybe I should have listened. Change the whole instrument panel instead of installing an aftermarket tach. But... had to do it the hard way....
Bought a Sun tach. Looked at mechanics manual to find tach(leads from ignition coil) wire in wiring diagram. Supposibly, its green with white tracer. In all wiring diagrams, only one wire should be green with white tracer. Is this it? seems to change to green wire and go to instrument panel. by the way, hooked up positive to cigarette lighter wire and negative to its ground.
picture is left of driverside foot well.
http://www.fototime.com/inv/210288895CBD519
and it is not working. ug... dont want to wire through firewall because cant find a good way through. Thanks anything apprecaited.. cant find anything in old posts..
posted a few other pics from the adirondacks.. "I wonder where this leads....."
