Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > South East Chapter
South East Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Old January 18th, 2007, 10:40
AlabamaBill AlabamaBill is offline
It's Build Time!
Okay, It is time to starting building. I figure I ll be be more mud then rock and it will be a mild off road rig with limited pavement driver. I would use it for play, hunting, store trips while hunting, and driving to hunting camp. I dont want a lot a lift, plan on smaller tires 30-31's. Okay now here for the advice.
How big of draw back is running a AX15 compared to AX5? It save money and work to keep the AX15. I have Chrysler rear end 27splines with 3:07s, though I have set of dana 35/30's with 3:73, or (suspected 4:10's or better out of 4 banger). Now, I could pick up ford 8.8 if 4:10s or 3:73s if none of the other items are recommended. I figure till I can afford a locker, (all rearends are open that I currently have) is to run a mini spool in which ever rear I use.
Now, I want 2-3 inch lift aka avoid a slip yoke at this time but not expend a lot in case I want to go to 4 plus in future. So, I want to do a junkyard lift, I looking at either ford f150 or jeep grand V8 coil springs on front advice here please??? For the rear a bastard pack with use of dakota or s-10 but advice on spring comibination for 3 inches not the 4 inch I find in searches?
I cant afford a which at this time but what would you recommend with enconomy in mind, suggestion on bumpers and tow points, gonna get fab suggestion on thickness, materials, blueprints etc?
I begging for input but dont what to post this in general since I prefer to hear from fellow southerners, yes I dislike yankees.
Thanks
Bill Carraway
Moulton, Alabama
Old January 18th, 2007, 11:41
Jess Jess is offline
Re: It's Build Time!
If you are only going to run 30's or 31's the 307 gears should be fine. I would stick with the 8.25 as opposed to the D35, but the 8.8 is also a good option (you will need spacers with the 8.8 because it is narrow).
For the lift, if you are only wanting 2-3 inches, you should go with a budget boost with front spacers and a rear shackle or long aal.
I think I saw a Ramsey 8500 in the vender forum for 400 shipped. Make sure not to slack on strengthening your frame rails.
Just for your reference, I have known of several people running 5-6 inches with no sye.
Old January 18th, 2007, 12:27
caglezxj's Avatar
caglezxj caglezxj is offline
A ax5 was put on the 4 cylinder engines and are weeker trannies. I would stick with the ax15. For the rear ends I would run the chrysler and regear or go with the 8.8 with lower gears. Stay away from the c-clip axles as much as possible. I have some dana 35 chromo shafts if you are interested. I believe I need 250.00 for both. the 35 I have has 4:88's yukon axle shafts and a lock right locker. I believe you could get it for around 600.00 However it is out of a TJ. And for lockers a lock right will cost you about 289.00 , spooling would be cheaper, or you could even weld it if you wanted. But that would not be the way to go if driving it on the street.
Josh
Old January 18th, 2007, 12:35
caglezxj's Avatar
{ You can do a budget boost and run the tire size you are looking for. I believe you can do one of those for under 200.00 pretty much spacers and add a leafs. But you are looking for cheap.}
{ Mile Marker makes a good winch, and the owner of Wheelin in the country, buys the Sams Club winch and runs it till they die. He says they last a couple years and he puts them through hell. I believe he gets them for around 350.00 or 450.00 . On the bumpers, I make all my stuff out of DOM, However HREW works but it dings easier. Make sure to turn the seam to the inside. That is for tubing. If you want to use rectangle tubing, use 3x6 or 3x8 .250 wall. You can make the brackets for mounting to the unibody out of 1/4 x 6 steel flat bar, and make some compression sleeves to go inside the uniframe and another flat bar on the back side. There is several ways to do this, search here, and look on the web. Hope this helps some.
Old January 18th, 2007, 20:33
ChuckstrPT's Avatar
ChuckstrPT ChuckstrPT is offline
NAXJA Member #791
Easy there Bill....there may be some of those darn Yanks among us.....
as for the build...keep it simple with spacers, and build some good protections, bumpers, rails, skids. Sam's occassionally has a 7500 no name winch for $300....I'd get it if it would fit in my bumper!
Old January 19th, 2007, 10:03
dummy me, I meant I had option with a auto AW4 not AX5 or now that I have looked up somethings, it gonna be a chryo 904 w/207 I got setting out back, will check out bolt pattern in a bit.
So 1/4 is recommend thickness on supports, re-inforcement, etc. lot of wt, Wondering if BB would be a bit overload on factory springs was reason I had left that option off and went with ford springs and bastard pack. I thankfull for imput!
Josh, how much for a lesson in how to run that Henrod 2000 torch btw? I cant figure mine out. Maybe we can set something up this weekend or first of the week. I ll drop mine off for repair.
I guessing based on opinion of fellow "southerners", I leave in chryo 8.25 3:07 for time being power by tried and true 4L, Ax-15 tranny for starters. hammer and weld in some good tow pts, and slapp some tires on... oh well getting ahead of myself.
I just bought a single RE1463 spring 3.5 for 25 bucks so looks like my lift is growing LOL. (is that how it always works) So now we are looking at 3 to 3.5 inch lift so back to spring issue and now for shock advice
Thanks
Bill
Old January 19th, 2007, 10:20
I would stay away from the ford coils because they are very stiff and do not flex well. I have seen some 3 inch coil spacers on ebay pretty cheap or you could get new coils for about 150. Remember with 3 inches, it is likely you will need some longer lca's to keep the vibes down.
Old January 19th, 2007, 12:18
caglezxj's Avatar
New coils from rusty's is 150.00 a pair. I don't know how much for other companies. Also you can not beat the Auto. I love mine, I hammer on it and it holds up. But if you are towing a lot then maybe the AX15 would be better with the higher gears you have. I can show you how to use the henrob it is easy. About repairs it will be a another 2 weeks or so before I start selling these. I can get your parts though no problem. I am working sat. maybe sunday. Shoot me a p.m. with your number again and we will try to set up a time to meet up.
Old January 19th, 2007, 12:40
ChuckstrPT's Avatar
NAXJA Member #791
I got my 3 inch Skyjacker coils off this board for 80 shipped, and I've got no complaints. I've got an ARB up front, but no winch. I think they'll settle a bit with a winch. The ride has been good, as well as the articulation. I think I may eventually go to a 4" spring, anticipating bigger tires, and a winch....
I'd keep your eye on the for sale board, it's been good to me, and springs come up fairly regularly, specially the 3-3.5" variety, as everyone goes bigger...
Old January 19th, 2007, 12:41
ChuckstrPT's Avatar
NAXJA Member #791
I'm at 3 inches with stock length LCA's, not stock, but stock length...no problems, not even in Full Time...
Old February 4th, 2007, 22:28
AlabamaDan's Avatar
AlabamaDan AlabamaDan is offline
How's your build going?
Old February 5th, 2007, 17:38
Slow have had an inner ear problem and not able to turn a wrench much. I have been primarily shopping around for stuff. I got rear springs, LCA's, shocks, plus some misc stuff I need for repairs in other areas, New front fenders, radiator, electric cooling fan etc. My current major need is front springs for about 3 to 3.5 lift or smaller with spacers. I am also bargin hunting for 8.8 ford in local junkyards in 4.10. I have a dana 30 4:10 for the swap. So making progress but still long way. June may be realistic LOL
Thanks
Bill
Old February 8th, 2007, 16:17
UPDATE: Bought 98 Ford Explorer 8.8 with disc (minus a caliper), 4:10 gears factory posi for 150.00. I also have wheel spacers, shocks, and springs, on the way for the rear. So Rear parts about 80% found.
The front is different story, got 30 with 4:10 gears waiting to be pulled and that is it.
No progress on tow points to speak of but got some ideals but lack of funds at the moment.
Bill
Old February 11th, 2007, 09:02
Okay, I am running out of Money for a bit and need to get the wheels back on the road so to speak. I need a find the cheapest way to put shocks on the front that will handle 3.5 lift. Got a used in good condition for back. So what shock guys? I have brand new front OEM style on it now...well 8 miles on them.
So My first Off roader looks like, 3.5 RE lift all the way arround, 8.8 ford posi/dana 30 open 4:10, 4L, Ax 15 all riding on 31's. Tow points still in the works. Should have it back on pavement and rolling this week. Upgrades to axles will have to wait a few weeks or month or two. May eliminate c clips on 8.8 and go to a full spool and some sort of lunch box in the front.
Also eyeballing a 3 speed monster box for a summer fall upgrade, question do you really need that kinda crawl around here? I dont see me climbing a telphone pole or anything
Thanks
Guys
Old February 11th, 2007, 21:50
ChuckstrPT's Avatar
NAXJA Member #791
Here's a link to what I've got on my garage floor. I ran them stock and with 3 inch springs. I'm sure I could make you a good deal!
http://www.naxja.org/forum/showthread.php?t=904724
Rate This Thread:
Mechanical difference between part time and full time Mopar500 OEM Tech Discussion 9 December 22nd, 2006 14:25
Part Time 4wd vs Full time? KiwiXJ OEM Tech Discussion 13 March 6th, 2006 13:21
To build or not to build mtnbikeboy OEM Tech Discussion 2 January 10th, 2005 20:35
part time full time 4wd? biscuitboy87 OEM Tech Discussion 5 November 5th, 2004 02:11
can you switch the part time light to full time ? Dano Modified Tech Discussion 9 October 9th, 2004 08:58
