RichP
- Effort, Pa
Came across an interesting trojan hijacking this afternoon working on a customers system.
Sympton was not evident *until*, an example, you did not type a full URL in the browser, like you type www.sears.com it goes there, type sears and you end up at an adult search engine site. Drove me crazy for a couple of hours, finally found it, the trojan was forcing a change in the network setup, leaving DHCP from the DSL modem and firewall alone and leaving DHCP on the workstations IP alone but forcing it's own DNS servers into the configuration which would put your browser on their web site. So if anyone has noticed that their search engine has suddenly changed to undesired sites look there first. Under normal DHCP from your cable modem, firewall or DSL router THEY supply the DNS servers unless you have manually changed it at some point, if you pop your network interface up, right click properties and then look at TCP/IP > DNS servers and there are entries you did not put there you got a hijacker onboard.. OH yea, it also turned on the remote control for remote assistance.
