Big Red
- Roscoe, IL 61073
MORE motor mounts problems getting them bolted up.
I did the driver side 1st and between me and a friend who is very mechanically inclined, we couldn't get the motor mounts to bolt up. We used a thick 2" x 1.5' board on end and jacked it up with a 2-1/2 ton jack to the front edge of the motor and haven't been able to get the bolt through the mounts and the fork. I have a 1" t-case drop since I went with a 241 Rock Trak t-case. Do you think I'll need to unbolt the trans mount? Should I 1st bolt up the new motor mount to the fork and then bolt in the 2 bottom bolts? I have about 2-1/2 hours with someone on the driver side mount alone and cannot get the bolt now through the mount, the mount is still up a little on 1 side and down on the other. Should I try jacking up the motor on the lower most part of the oil pan where the drain plug is. It seems like I might need to pull the motor forwards, how would you do that? I tried rachet straps, but they aren't helping much. Please help. I have a 8000i Warn winch, would anyone use this?
thanks,
Troy
thanks,
Troy
