Window Washer Does Not Spray
Mighty.Mighty_XJ
99 XJ - When I hit the washer switch, it sort of squirts out some water, but it doesn't spray onto the windshield. The wipers work fine. Should I be looking at the washer pump or the little holes on the hood? Thinking of tackling this tomorrow if the temps are ok and am hoping that it'll be a straightforward fix. Thanks for any guidance.
Check the pumps and their wire connections, it is likely the pumps are rusted or failed and need replacement.
X2 on nozzle clogging.
Can you hear the washer motor come on? If it sound strong like normal but no washer fluid sprays, there is probably a blockage in a line or it’s broken someplace, or the nozzle is clogged. Very off chance some sort of slime formed and is blocking the pick up screen in the reservoir.
For clogged nozzles I’ve either replaced them if cleaning failed with new or junk yard. Well junk yard source for the jeeps, new for the Honda and Toyota cause the plastic is more brittle after years in the southern sun.
Weird fact that’ll probably help nobody is the 84-86 XJ have a different set up of only one nozzle and later XJ have two. Since there aren’t many 84-86 XJ in junk yards I grabbed a nozzle from a mustang with similar set up.
