justin_502
- ACTON, CA
I did some research but I just want to make sure before I go buy parts. On a 90 XJ an upgrade to a worn out steering system you can get. A pitman arm of a zj and it is 1 inch drop? The tie rod end that comes off the pitman arm, that sleve and after that do they call it the center link or drag link? Also the lower part the 2 tierod ends and the big link that connects them. Does anyone have any recent part numbers they used, and is there anything I should watch out for, or any mods needed to make fit?
