NAXJA is having its 18th annual March Membership Drive!!! Everyone who joins or renews during March will be entered into a drawing! More Information -
Join/Renew
Any writeups on this or is this pretty straight forward? I did search and found very little info. Just pry out the seal, use bearing puller and installer to install new bearing and seals? Any other info I might be missing? Thanks Jeff
use an 8mm 6pt combo wrench. do not use a 12pt socket or combo as its very common to round the crosspin bolt.
I also find alot of times thats its easier to cut the old bearing out rather than try and pull it out. I mean I have lots of practice at using a slid hammer, but even I get tired. :wierd: :rattle:
push a rag into the tube before you cut/pull. That will keep bearings from going in further than you wanted.
inspect the shafts for galling and pitting.
have fun. should take you no more than an hour.
