1992 no start/occasional start rough running
831_xj
Santa Cruz
92 I bought occasionally starts but runs rough. Giving it any throttle will make it bog and die and then will not start for a while.
List of items replaced
Relays
Battery
Grounds cleaned
Crank sensor x2
Plugs wires rotor
Fuel pump
Upstream o2
Map
Suggestions?
I would pull the fuel rail off and check the injectors. It sounds like it is flooding and a lack of vaporization from the injectors could be the culprit. Pretty easy to clean with lots of Youtube video's out there on how to do so in your garage without special tools. Plus, it is a pretty easy thing to check. While you are in there you can also confirm that the rubber seals are in good shape.
HTH
Todd
