- Southern Maryland
A couple of months ago I installed a hack-n-tap on my 242. There was a leak at one of the bolts, the fluid ran out, and the transfer case started to make some noise. I was about 300 yards from a Car-Quest so I ran inside and bought some more fluid, filled it up and drove it home. Now the transfer case makes noise all the time. Usually its a very subtle clacking noise, but sometimes inside the car it sounds like gravel in a blender. I've put the car on a jack and listened with it in gear, and the noise is emanating from the rear half of the transfer case. The shaft isn't wobbling and I've already swapped drive shafts a couple of times. I'm guessing the chain is dragging but it sounds more like the gears are off the tooth or something. Anybody else experienced this noise and want to tell me what it is? I'm thinking about buying another transfer case to swap on while I tear this one down for a full rebuild, so I'm looking for some input here too.
Thanks
Thanks
