Installing motor back into jeep. Where does this go???
Jeese18
Cincinnati
Im puzzled. Its a red cable with a 90 degree bracket that mounts somewhere, connected to it is another mount that has 4 little holes around the main hole. Looks like it come from battery cable.
I can text a pic if someonw has any idea on this.
I have almost all the wires and connectors plugged back in bu i cant find where this came from. It falls from wire harness near battery and such.
Year model?
Post a pix.
At a guess it sounds like the alternator harness.
Dont have enough posts to add pics i think.
1999 xj sport 4 door, np231, etc...
Naxja does not host pix. You need to same your pix on a hosting site and link it here.
Sounds like it goes on the alternator. NAXJA does host pictures if you're a paid member. Any of the hosting sites other than photo bucket should work.
Starter feed?
Good deal.
Okay ill get photobucket up and running again and post a pic.
Alternator is already hooked up..
Boy are you in for a surprise... ;)
Who built the motor?
